  Finally... clutch time...
Finally... clutch time... by thesameguy
Started on: 05-13-2021 03:08 PM
Replies: 20 (468 views)
Last post by: thesameguy on 07-07-2021 09:59 PM
thesameguy
Report this Post05-13-2021 03:08 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been doing nothing about this car for years, but had a crazy dream about it and that has caused me to move.
I was agonizing over trying to get the transmission out the side, but I've resolved to drop the whole cradle... and I'm just about ready to do that.
I have a couple questions...
1. What is this pipe *supposed* to be for? It's connected to the air box on one end, but nothing on the other. The car has a 3.4pr swap, so I'm thinking it may be left unused as a result of that, but it's also possible the shop that did the swap (before I owned it...) ran out of talent. Lots of places where they did that...
2. Is there a way to separate the two halves of this connector? One half is very married to the the body, the other half to the engine wiring harness. The latter is something I likely did... if I can avoid undoing my superb cable management, I'd like to.
I was surprised to find the coolant pipe drain came out easily on this side.
I was not surprised to find the coolant pipe on the other side had been damaged and "fixed" ... no doubt by the idiot shop that did the engine swap. It's been fine for years, so I'm not gonna mess with it... just annoying anyway.
[This message has been edited by thesameguy (edited 05-13-2021).]
Report this Post05-13-2021 03:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's no longer used due to a recall, and it was supposed to be capped on the end. If it hasn't been, then engine bay air has been drawn into the filtered side of the air filter canister for decades.
thesameguy
Report this Post05-13-2021 04:03 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gotcha... it is capped. Or rather pinched. Thanks!
Report this Post05-13-2021 05:14 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
#2 is C500 is Three sections.
main ½ is screwed to body.
other ½ is actually 2 ¼ one to engine, other to taillight etc.
Loosen the bolt holding all parts. Bolt is captive to one part so Do Not try to remove it.
Maybe a 3/8 or 7/16" not metric. Some hardware isn't metric and easy strip w/ wrong tools.
thesameguy
Report this Post05-13-2021 05:16 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting... I will take a closer look at it!
thesameguy
Report this Post05-13-2021 05:36 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
thesameguy
Member since Dec 2012
Got it... I misunderstood how to separate the halves, but once knowing they were supposed to I was less hesitant and able to do it.
Next step - engine comes out!
thesameguy
Report this Post05-16-2021 12:14 AM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, here is how I started out....
This went really well. Engine right onto the dolly, super smooth.
Then things sort of went downhill... the TL;DR is that I couldn't find a good place to lift the body that didn't put the legs of the engine hoist directly in the path of the dolly. I ended up resorting to the trunk latch, which is not what I wanted to do, but here was my spin:
It wasn't a complete solution - that involved an hour-long curse festival - but I did emerge victorious.
The only thing during that process that made me actually happy with hanging the rear calipers from the body to avoid opening the system....
Anyway, I have a lot to do now, but a major concern is going to be how it goes back in. The "installation is reverse of removal" does not apply here - I'm not fighting that fight again!
thesameguy
Report this Post05-16-2021 04:27 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
thesameguy
I would say this is likely the issue.
Report this Post05-16-2021 05:11 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
⚠️ Warning: Never Do This...
Isn't "safer" then lifting by latch loop and those Nuts can fail at any time and without warning.
See my Cave, Jacking to Clear Engine
thesameguy
Report this Post05-16-2021 08:33 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I am aware of your feelings on the subject, but given the substantial evidence it can work and no evidence it's a problem, I took the risk. I considered using a floor jack under the frame rails, but given the angles involved it felt like just a different type of risk - stability vs. integrity. However, for the reinstall I'll probably go that route and pick up one of these:
https://www.harborfreight.c...ross-beam-64051.html
which should eliminate the stability issue.
Report this Post05-16-2021 08:58 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The legs of the cherry picker work great as a cradle dolly, which places the cherry picker close enough to use a chain in the cross beam.
For just a clutch job, I would have used the support bar from the top and kept the engine in the car (no need to disconnect harness, coolant or fuel).
[This message has been edited by fieroguru (edited 05-16-2021).]
thesameguy
Report this Post05-16-2021 10:08 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was originally planning on doing the clutch in the car, but decided that since crap was coming apart I would take the opportunity to do some other stuff:
1. Oil pan has a seep, so gasket will be replaced
2. When I installed the WCF manifolds I tried header paint, and that didn't last - I'm sending out the manifolds and y-pipe for ceramic coating
3. The paint has been flaking off the top intake manifold and one of the valve covers, so they're getting powder coated
4. Car has an '88 rear cradle, most of the bushings are shot - they're all getting replaced
There are a couple other minor things I'm considering (eg water pump as I have no history there) but this stuff was enough to compel me to pull the whole thing and work in relative comfort.
I got held up today as I can't find my dowel remover so I can't put the engine on the stand. Eh.
ZaraSpOOk
Report this Post05-18-2021 06:18 PM Click Here to See the Profile for ZaraSpOOkSend a Private Message to ZaraSpOOkEdit/Delete MessageReply w/QuoteDirect Link to This Post
oouch!
hopefully that can be straightened
[This message has been edited by ZaraSpOOk (edited 05-18-2021).]
thesameguy
Report this Post05-19-2021 02:21 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Haha.. it's gone. I'm replacing everything in there!
thesameguy
Report this Post05-19-2021 09:08 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
thesameguy
I couldn't find my dowel tool ... thinking I loaned it to someone and it didn't get returned. :/
Well, necessity is the mother of invention.... 1/4" NPT tap, washer, quick release fitting, and a slide hammer solves it.
Happily relocated to an engine stand...
Now to throw money around!
thesameguy
Report this Post06-12-2021 12:18 AM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
To keep this updated:
This happened....
https://www.fiero.nl/forum/Forum2/HTML/145157.html
which lead to:
https://www.fiero.nl/forum/Forum2/HTML/145162.html
and now I'm waiting on WCF for F23 install parts. I figured it would be foolish to start buying up F23s until I actually had - in hand - the stuff needed to install one.
While I'm waiting, I can work on the engine side. Step was one this:
I had some stuff going in for another project, threw the Fiero parts in the box. If anyone needs ceramic coating done, I highly recommend Performance Coatings in Auburn, WA. This is the fifth or sixth order I've sent their way and they always do a superb job at a reasonable cost.
I mostly just wanted to clean things up, but I'd be stoked if it cuts down engine bay temps a bit.
Notorio
Report this Post06-12-2021 03:59 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you remove the restriction in the Y-pipe?
thesameguy
Report this Post06-14-2021 01:04 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I did that a while back, when I installed the WCF manifolds. Well, I paid someone to do it. I don't have a welder.
Notorio
Report this Post06-14-2021 11:28 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has the smog tech ever noticed the non-stock WCF manifolds? They look so much like the stock logs as it is. Still, some people say that anything that looks 'new' is going to be suspect.
thesameguy
Report this Post06-15-2021 04:14 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope. I have two tests with them and nobody has said anything. Unless you had them next to each other or knew *a lot* about Fieros, there's no way anyone would know.
It's the same conversation with the digital EGR... I don't think most techs would ever notice the wrong EGR valve was there.... just *a* valve being there is probably enough. I know some techs do actually look at the vacuum diagram, so that would potentially be a secondary issue, but I'd wager most just look to be sure all indicated components are connected, and there's no vacuum hoses hanging around. I'm sorely tempted to try, but at this point I really just want this car back on the road.
thesameguy
Report this Post07-07-2021 09:59 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The red paint on the, well, red parts was falling apart, so now it's blue.
And, got a big heavy box from SoCal:
I was almost convinced it wasn't gonna happen.... now I gotta go find some F23s....
[This message has been edited by thesameguy (edited 07-07-2021).]
