  Proper way to support Fiero on 4 jack stands
Proper way to support Fiero on 4 jack stands by Skybax
Started on: 05-14-2021 05:52 PM
Replies: 11 (1059 views)
Last post by: Skybax on 05-15-2021 07:54 PM
Skybax
Total ratings: 78
Report this Post05-14-2021 05:52 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm putting my Fiero on 4 jack stands (no wheels and tires) for a week. I've worked on cars for 40 years and have common sense, but I wanted to ask if anyone had suggestions on the "proper" or "ideal" placement on the frame/cradle to support it for good stability/balance, thanks.
(also plan to putting a few 4x4 pieces in other areas just in case one of the jack stands would fail)
[This message has been edited by Skybax (edited 05-14-2021).]
Total ratings: 154
Report this Post05-14-2021 06:06 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Save the chart image in your files. Every time you take it to a place to be serviced, print 2 copies. Place 1 in the driver's seat and give the other to the service writer.
https://www.fiero.nl/forum/Forum2/HTML/143481.html
Skybax
Total ratings: 78
Report this Post05-14-2021 06:17 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the link...
I'm not taking it to get serviced and I'm familiar with Fiero jack points, I'm putting it on 4 jack stands and was just looking for ideal balance points, thanks.
Skybax
Total ratings: 78
Report this Post05-14-2021 06:58 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skybax
Member since Jun 2003
By default I would put front stands on front cross member and rear stands on rear cradle at most forward position, but thought maybe there might be better placement, especially at rear.
Total ratings: 328
Report this Post05-14-2021 07:04 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would put two jack stands at the rear on the cradle and two near the front on the channel reinforcements in the unibody or on the cross member. When we use the two post Rotary lift the lift points are on the cradle and body channel. When we drop the cradle the lift points on the rear are the jack points
Report this Post05-14-2021 07:27 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Safe Jacking & Jacking to Clear Engine
Likely use 4 points far apart.
⚠️ Warning: Unless you do this on Level Concrete surface, Jack Stands can/will Move under load over time. Time can mean minutes, hours, days or longer.
Asphalt and dirt often hates point loads from anything. Worse if they get hot or wet.
Most people don't know that Asphalt never dries. Is a super thick fluid that will flow even in cold weather but you won't see that normally, likely not even in you're lifetime. In very hot weather... Any w/ high heels can have problems. That isn't just a gimmick from movies.
If it does "dry out," the road or whatever is very old and turning to dirt.
Related to "The Pitch Drop Experiment," just web search that name.
But when you point/edge load, bad things often happen even at "room temps" depending on exact surface.
3 or 4 leg stand and wheels on jacks can sink fast and often don't sink at same rate letting the top to shift or drop the load w/ little or no warning.
Semi Trailer can sink the jacks on front of trailers too. Is why many drivers have big wood pieces to spread the jacks footprint on iffy pavement etc.
Skybax
Total ratings: 78
Report this Post05-14-2021 10:09 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, just to clarify... are you suggesting Example A or Example B in images below?
reinhart
Report this Post05-15-2021 05:37 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
A). But use discretion if you're working on something. e.g. Don't block what you're working on.
Total ratings: 154
Report this Post05-15-2021 09:45 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skybax, Example A has 8 locations indicated for safety (jack) stands, 4 of which you circled.
I included the suggestion for printing out the graphic in the event you ever did have to take it to a service department. Maybe to get a new set of tires, perhaps?
skywurz
Report this Post05-15-2021 11:37 AM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I prefer supporting on the blue circles below and jacking on the red. The orange rectangle represents where I like to support with a 4x4 on jack stands for a cradle drop.
Edit.
Also be careful when putting the whole car in the air. Make sure your stands are not tilting. If your jack gets hung up and is not rolling freely it can push the car and rock the stand or cause it to shift on the stands.
[This message has been edited by skywurz (edited 05-15-2021).]
cvxjet
Report this Post05-15-2021 02:30 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I jack the Fiero up, I put the floor jack under the front crossmember or the back of the rear subframe(I even marked dead-center on the frame). When I place the jack-stands I put them as far out on the front crossmember or on the two rear corners of the rear subframe.
Critically, when I drop the car onto the stands at the rear (With the front on the ground) it will move forward, so I always place chocks in front and back of tires on end left on the ground...after lifting but before lowering, I move chocks if needed to make sure there is no large shifting of car during lowering. After I lower the car, but before removing jack completely, I grab car and give it a shake to make sure it is solidly supported.
If you place jacks as shown in FRONT of the engine, those stands will be supporting most of the car's weight- 1500 lb stands are not strong enough. I would use 3000 lb to 3 ton stands...Better to be safe than.....squished!
While working at NAS Alameda, one of my co-workers was working on his RV.....His >>CAR<< jack-stands failed.................>>End of story<<
Skybax
Total ratings: 78
Report this Post05-15-2021 07:54 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is exactly how I would have done it, was just curious what others do for optimum balance/stability points.
Good tip for many folks out there, I only use 3 ton myself for most cars, and I would never lay/work under a car that was only supported by jack stands.
I've never taken my hobby car to have tires put on or be serviced, I don't even like others working on my daily driver. I do 95% of my own work, having somebody else work on my car is last resort. Over the last 40 years I either mounted them myself when I worked as a technician, or these days I just take them the wheels, hence the purpose of having car on jack stands for a week or more, which I'm not happy about. To elaborate... I'm pulling wheels, take wheels to local garage to dismount tires, take wheels to be stripped in a soak tank, I'll polish machined lip, paint and clear coat wheels, take restored wheels and new mail-order tires to be mounted, then reinstall. This is probably the 20th set of wheels I've restored (different makes/models) and normally I would strip them myself, but I'm getting older and don't want to deal with intricate diamond spoke webbing, so stripping via soak tank is easier way to go on GT wheels.
[This message has been edited by Skybax (edited 05-15-2021).]
