  Notchie LED Tail lights.
Notchie LED Tail lights. by str8maxn
Started on: 05-20-2021 10:03 PM
Replies: 8 (546 views)
Last post by: theogre on 05-26-2021 06:54 PM
str8maxn
Report this Post05-20-2021 10:03 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello all
I am in the process of wiring some LED tail lights into my Notchie but I am running into a bit of a problem.
The LED light I plan on using is an all in one. Lights ON > Brake On > Turn Signal. The wiring looks like this :
O Lights on will have a Halo ring light up
O Brake will light the Halo ring much brighter
>>>>>> Turn signal will sequence inward out ( Like a Mustang)
Here is my problem; The brake and Turn signals are on the same circuit in the Fiero. So when I brake both signals will sequence once and stay on for the duration of the braking in addition to the brighter Halo.
When using the turn signal Left or Right, both the Bright Halo and Turn signals light up.
How can get a separate the Stop and Turn signal circuit?
I
[This message has been edited by str8maxn (edited 05-20-2021).]
skywurz
Report this Post05-21-2021 01:32 PM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the notch back the stop and turn will be the same. The stop power is routed through the turn signal switching at the column. If you had a GT there is a separate circuit run back there for stop only. However turn would still be turn and stop. When you switch the turn signal it moves the current from NC for the Stop/Turn signal from the brake to the turn signal circuit. The Hazards are a different config.
str8maxn
Report this Post05-21-2021 01:38 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
This really sucks..... I did something similar in the Fast Back I had and figured I could duplicate it in the Notchie.
Thank you for the reply.
Trinten
Report this Post05-21-2021 04:38 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
It looks like you could still do this, but you'll wind up having to run some new wiring to create a new circuit. I think it would be a cool project, especially if you do some detailed documentation on it. Other notchies folks would be more inclined to dive in that way!
str8maxn
Report this Post05-21-2021 07:10 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would you happen to know where the turn signals link up to the brakes. I am assuming I could cut them there and run new wiring to the Left and Right Turn signal.
Report this Post05-22-2021 12:19 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ignore above posts.
Always post Year of car.
86-88 have "GT" yellow turn lights wires all the way to C500.
Only need to cut a white jumper to "reprogram" this and wire brake light to C500.
Cut jumper at middle so can restore if needed or to wire new brake lights to ½ of same.
Should be easy to find ever w/o pulling C500 retaining bolt on front side plug.
only 84 and 85 needs brake light wire all the way to the dash. Cutting white wire to the column from Brake light switch.
But 84 has more issues because uses all bulbs for stop/turn and relays too. Need to pull 2 relay plugs and protect them from water etc.
In all cases... You wire new turn lights to the same stop/turn wire in the back. Just splice this. Do cut out old sockets...
LED have many problems even when you use DOT Legal set made for other applications. Sit at a traffic light sometime and watch newer trucks w/ part or total dead LED taillights. Trucks/Buses cost $50,000 $100,000 or more yet LED taillight are dying < 5 years often < 2 years.
Most for the aftermarket are illegal or maybe legal but just crap and die fast.
If taillight are dim...
Check wiring and ground hidden by body in 84-87 Fiero. You likely need to do this just to make new light work.
Clean and repaint the the shells and use 2357 bulbs.
changing OE 2057 or 1157 to 2357 is a Big Difference for any Red taillights. (Don't use this in Yellow turn. Bright here can "blind" anyone behind at night.)
[This message has been edited by theogre (edited 05-22-2021).]
str8maxn
Report this Post05-25-2021 12:45 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
Ignore above posts.
I decided against modifying the turn signals to work on a separate circuit. I also avoided cutting into the existing wiring. I used pre wired 1156 and 1157 bulb inserts. I am happy with the out come.
I could could also but everything back to stock.
theogre... Thank you again for all the great feed back.
Report this Post05-26-2021 02:45 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by str8maxn:
.. I also avoided cutting into the existing wiring. I used pre wired 1156 and 1157 bulb inserts. I am happy with the out come.
I could also put everything back to stock.
I did this as well when I modifed my tails. It does simplify things. If I had seenthis thread earlier I was going to recommend it.
Report this Post05-26-2021 06:54 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
LED "inserts"?
Most are crap made.
Keep old lights when the LED's fail.
Or Replace w/ 2357. Changing 2057 or 1157 to 2357 technically illegal but no-one in the US and other Countries is going to notice because most vehicles Have 2357 as OE bulbs.
Isn't a lot brighter but brake/turn lights up faster then old bulbs.
Many like Sylvania have "off road" warning on the package but sold next to normal bulbs at AZ, K and W marts and more.
Others "off brand" or no name units have same warning, often hidden and fine print like "Pilot" brand, or nothing and make very cheap and won't last.
And if the unit is labelled as "CANBUS error free" etc. the resistor in them eats power and make heat that can kill the LEDs. see Smokin' hot CANbus LED lamps. (230C in open air.) - YouTube https://www.youtube.com/watch?v=tkPGqM0Sl64
While that have "161" LED bulb, 1157 CANBUS and others have same problem.
