  GM p/n 24503860 Acuator Timing Belt Tensioner
GM p/n 24503860 Acuator Timing Belt Tensioner by novars
Started on: 05-29-2021 09:45 AM
Replies: 15 (986 views)
Last post by: novars on 06-01-2021 06:57 PM
novars
Report this Post05-29-2021 09:45 AM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking for this part. I came across this post while searching: https://www.fiero.nl/forum/Forum2/HTML/142611.html
People posted that there are a number of them available on the Internet in 2019 but I have not been able to find any. I was wondering if there is a warehouse that stock piles old parts or if there is a data base that is linked between GM dealerships or something similar. I have not had any luck finding any.
Does anyone know where I can find this part? Thanks
IMSA GT
Total ratings: 253
Report this Post05-29-2021 10:17 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the rarest of the rare. Hopefully someone has one on here.
[This message has been edited by IMSA GT (edited 05-29-2021).]
novars
Report this Post05-29-2021 10:30 AM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I already went through that website and every inquiry says discontinued. Thanks
novars
Report this Post05-29-2021 11:04 AM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
novars
Member since May 2021
http://oemcats.com does not appear to be reliable.
msweldon
Report this Post05-29-2021 12:18 PM Click Here to See the Profile for msweldonSend a Private Message to msweldonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your best bet is to find one, or several, from a junkyard LQ1, all model years have the same one, and R&R them... they are quite easy to rebuild and the FSM has pretty good instructions..
IMSA GT
Total ratings: 253
Report this Post05-29-2021 01:19 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I was wondering, if they were rebuildable.
novars
Report this Post05-29-2021 01:22 PM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have never had a part rebuilt. Where would this be done? I can get a rebuilt starter at a shop that does a better job then one from Autozone, etc.
msweldon
Report this Post05-29-2021 02:27 PM Click Here to See the Profile for msweldonSend a Private Message to msweldonEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I say 'rebuilt' it's relative.... pull it apart as its very simple.. make sure the bore isn't pitted or the boot torn or leaking... no horrible play in the bore to piston, etc... clean then reassemble... it's nothing fancy at all.. just spring loaded with oil to keep things moving...
Total ratings: 328
Report this Post05-29-2021 05:59 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You often find leftover parts like this at the auto swap meets. I've seen vendors with barrels full of GM parts still in the box offered at $1 ea. and no one knows what they belong too. This hydraulic belt tightener is obviously a hard to find part but somewhere they are out there. The 3.4 DOHC engine was only made for a few years so finding special parts has got to be hard. I feel your pain as I was trying to find a new oil pump for the 4.9L Cadillac engine and like yourself I looked everywhere and came up short. I'll just keep looking and just maybe one will show up.
novars
Report this Post05-29-2021 09:57 PM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm planning on have the belt replaced and wanted to gather the parts. This is the only one I haven't found yet. I am looking into the rebuild idea and just scouting around at swap meets is also a good idea.
bonaduce
Report this Post05-31-2021 06:09 AM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will run the number through the GM website/located tomorrow when I get to work and see if any are out there.
novars
Report this Post05-31-2021 11:43 AM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
bonaduce
Report this Post06-01-2021 10:01 AM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are 5 available in th US.
1) Itasca Ford in Cranston RI has 2 as of this am (401) 681-1300
2) Bareford Buick in tappahannock VA has 1 (804) 443-3500
3) Brown chevrolet in Eagle pass TX has 1 (830)773-2349
4) rydell automotive in Northridge CA has 1 (818) 832-1660
Good luck hope this helps in the search
Dan
novars
Report this Post06-01-2021 11:28 AM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
TX and CA should have them. I am waiting on confirmation. Prices are steep but that's OK. VA looked for it last week and could not find it.So maybe they have it and maybe they don't. RI doesn't have any. Thank you for the best lead so far.
novars
Report this Post06-01-2021 06:54 PM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
novars
I am getting one each from TX and CA. Just be on the safe side in-case one is defective. My car and I thank you.
novars
Report this Post06-01-2021 06:57 PM Click Here to See the Profile for novarsSend a Private Message to novarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
novars
Question: When I spoke to my GM dealer parts dept, they said discontinued, gave me the part # and then that was it. Could they have found it like you did OR do you have a different system? I'd like to know if my dealer is really willing to help or not really that interested. Thanks
