  HELP !!! Trunk doesn't open
HELP !!! Trunk doesn't open by 85fieroguy
Started on: 06-05-2021 03:22 PM
Replies: 3 (302 views)
Last post by: theogre on 06-06-2021 11:31 AM
85fieroguy
Report this Post06-05-2021 03:22 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 85 GT now has another problem out of the blue. The key fits in and turns to the right. but I don't get a release sound. Darn, with the engine side vents secured under the trunk lid..HOW DO I GET THE TRUNK DECK LID OPEN???? HAVE THE LOCK BORED OUT ??
Report this Post06-05-2021 03:38 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lots of helpful info in this thread - Only Trunk Key Accidentally Locked in Trunk
Mike in Sydney
Report this Post06-06-2021 09:25 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have a remote trunk release switch of is this on of the rare cars w/o it? IUf yoiu have the switch an it's not operating, have you:
1) Checked the fuse?
2) Checked the wiring you can get to?
3) Checked the switch?
4) Checked the relay?
I had a problem where the trunk wouldn't release when I pushed the button. The fuse was good but as was the wiring. When I pulled the switch out, I found that the connector on the back of the switch had either been removed or had fallen off. I cleaned the terminals on the switch and in the connector as best I could, added a bit of dielectric grease and put the connector back on the switch. Pushed the button and bingo-bango, the trunk popped open.
Report this Post06-06-2021 11:31 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't continue this thread here... Just a wast of Time because He has Multiple Threads in 2 forums for same Problem.
See...
Trunk opening problem https://www.fiero.nl/forum/Forum1/HTML/099796.html
Trunk not opening solved https://www.fiero.nl/forum/Forum1/HTML/099799.html
