Today i took the buckets and sprayed them.
While those dry I worked on wire routing.
I moved everything to the headlight bucket and routed the cables.
as you can see now my grommet fits again as i was able to just sneak an extra cable through it.
Got this cross cable bolted down and secured.
Now that the cables in the front area are all secure and routed I put in the new bucket
I set down the hood and.... hmmm somethings not right. The hood was a struggle to close ( i was careful)
I look and see its hanging up on these bolts that i have swapped around.
I can not put these bolts in the other way
I loosen the bolt and re close the hood.
Much better
Now i need to figure out the bolt situation
Get the other bucket installed
Finnish running my hot cable through the interior and to the batt.
