  Code 24
Code 24 by kett48
Started on: 07-06-2021 05:31 PM
Replies: 1 (536 views)
Last post by: theogre on 07-06-2021 06:02 PM
kett48
Report this Post07-06-2021 05:31 PM Click Here to See the Profile for kett48Send a Private Message to kett48Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 88 Gt with a 5 sp. I'm getting a code 24 (vss).When driving in 5th gear the car idles at 1800 rpm
It will eventually come back to 1000 rpm when I stop. I have changed out the ECM and the speed sensor on the transmission but, it didn't make any difference. I checked the continuity between the speed sensor connection and the connector underneath the dashboard and it appears ok. I'm thinking that it might be the speedometer circuit board. Any ideas? Paul
Report this Post07-06-2021 06:02 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
if speedo displays speed and/or odo then Not a VSS problem.
speedo board can't output 2000ppm or wire(s) to ECM is your problem.
see https://www.fiero.nl/forum/Forum2/HTML/145251.html
