  Car dies going down the road restarts immediately runs great!!
Car dies going down the road restarts immediately runs great!! by J.E. Rowlett
Started on: 08-22-2021 12:32 PM
Replies: 14 (399 views)
Last post by: Steel on 08-28-2021 06:51 AM
J.E. Rowlett
Report this Post08-22-2021 12:32 PM Click Here to See the Profile for J.E. RowlettSend a Private Message to J.E. RowlettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking to some GURU's for advice. I went to a car show yesterday about 40 miles from home. Car died 3 times while at road speed, did not run bad just shut off like I turned the ignition switch off. I pushed in the clutch and it started immediately and ran perfect. No driveability issue just shuts off. This is a pretty nice 85 GT, 4 spd fiero. well maintained. The trip there and back did this about 4 times each way?? Thoughts?? Thanks in Advance
Shho13
Report this Post08-22-2021 12:53 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
If your GT still has the 2.8, a faulty ICM (the little module under the distributor cap) will cause instant shut off issues; and usually only when the car is at operating temps and the module is hot.
Usually with this component however, the car won't restart after it cuts out until the car cools off a bit (if it's going to restart, that is). Failing ICMs are a very common issue, especially with the chinese parts that the market is filled with these days. Next time your car stalls and if it doesn't restart, crank it and take note of your tachometer, if the RPM needle goes up a little when you crank it, the issue *usually* is the ICM.
I keep a spare in my Fiero because over the ~8 years I've had mine, I've went through three. An easy change with only a phillips screwdriver needed; easy side of the road fix. They tend to last about 3 years before failing.
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Total ratings: 154
Report this Post08-22-2021 02:19 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had an 88 coupe that would do the same thing. It wouldn't restart unless the ignition was turned off, even for just a few seconds, then it would restart. Changed ECM's without result. I never found the problem, and neither did the subsequent owner.
But Shho13 probably has you on the right track for the V6. Even if it turns out not to be the ICM, you will have a spare, of which you should always have a spare with the V6. Some white or silver thermal heat sink compound, too. Not the clear stuff.
Total ratings: 465
Report this Post08-22-2021 03:44 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Shho13:
Failing ICMs are a very common issue... Next time your car stalls and if it doesn't restart, crank it and take note of your tachometer, if the RPM needle goes up a little when you crank it, the issue *usually* is the ICM.
Sorry, but I believe you have that backwards. A bad ICM will not move the tach needle while cranking.
Originally posted by Blacktree Here:
...when you try to start the engine, does the tachometer do anything at all? If the ICM is working, the tach should twitch a little bit during cranking. There should also be spark at the plugs.
My experience with an ICM going bad is that the engine will run rough before it dies. Then after the ICM cools down, the engine will start again... but the ICM is now on borrowed time.
Ray_and_kevin
Report this Post08-22-2021 11:14 PM Click Here to See the Profile for Ray_and_kevinSend a Private Message to Ray_and_kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 88 with 3.4 V6 Camaro engine does exactly what you describe. Took quite a while to find out what was happening. I changed the ICM but then it did it a few more times.
Finally found out that the problem is not the ICM but rather the two pin connector that connects the pick up coil in the distributor to the ICM. It is tin plated but there is steel associated with this as well. Our distributors are *NOT* sealed against moisture, so the connector pins oxidize and rust. Once the pins heat up, you can get an intermittent contact with the pick up coil. As someone else mentioned, you let it cool down and it starts working just fine.
The solution is to take the cap off the distributor and clean the contacts in the white connector. Just unplugging and reattaching is enough for a quick fix! Cleaning the connections and using dielectric grease to keep out moisture is enough to keep the connection working.
We were bringing the car back from Dayton back in 2014 and it started doing this right at the Texas state line. It started back up a couple of times, but eventually would just not keep going. Spent a day in Mt Pleasant,Texas waiting for my wife and daughter to bring the Tahoe and a trailer to fetch us from Austin. Thankfully we coasted a good 2 miles to the exit for Mt Pleasant!
J.E. Rowlett
Report this Post08-23-2021 12:24 PM Click Here to See the Profile for J.E. RowlettSend a Private Message to J.E. RowlettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the responses, Just before this little trip I had changed ECM and put in a Echlin unit. I also carry a spare . I don't think it is the ECM because if the unit fails (overheats) the car will not start until it cools down. My car starts immediately and runs perfect. Just dies. I will check all the pin connectors as one member suggested. I have owned this GT for 21 years and never had this problem!! GRRRR!
Total ratings: 154
Report this Post08-23-2021 01:06 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 88 Duke would restart immediately, too. Once I was in the middle of 5 interstate lanes in Atlanta traffic at 70 mph when it died. Clicked the ignition back 1 click so as not to lock the steering wheel, then back to start and it fired right up. I had to do that 5 or 6 times for the remaining 30 miles home.
I never got around to changing out the ignition module on the coil pack, but that could have been the problem. Something that's never considered is the actual ignition switch located underneath the dash on the steering column.
[This message has been edited by fierofool (edited 08-23-2021).]
Larryinkc
Report this Post08-23-2021 02:30 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a similar problem, it was caused by corrosion on the terminals on the junction block by the C500 connector. I cleaned up the ring terminals on the wires and installed a new junction block to fix the issue. Rodney has the junction blocks if that turns out to be your problem.
J.E. Rowlett
Report this Post08-23-2021 02:59 PM Click Here to See the Profile for J.E. RowlettSend a Private Message to J.E. RowlettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks larryinkc, not sure of the location of this terminal block?
Total ratings: 465
Report this Post08-23-2021 03:01 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by J.E. Rowlett:
Just before this little trip I had changed ECM and put in a Echlin unit. I also carry a spare. I don't think it is the ECM because...
Just to be clear, an ICM and ECM are two totally different components.
Larryinkc
Report this Post08-23-2021 03:20 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its on the right rear inner fender just after the battery.
J.E. Rowlett
Report this Post08-24-2021 08:56 PM Click Here to See the Profile for J.E. RowlettSend a Private Message to J.E. RowlettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks everyone I will check out everything you shared
Report this Post08-25-2021 11:42 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clean/fix + wire above and All "grounds" bolted to engine and engine bay.
Coat w/ Silicone or Brake Grease to stop future damage.
Even if isn't the root problem now... will be problem because of iffy "grounds" etc.
After solving current problem... Do same for other grounds in the cabin and front of car. They often need cleaning/fixing too.
See my Cave, Wire Service
Cliff Pennock
Administrator
Total ratings: 699
Report this Post08-25-2021 12:43 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I second (or third?) the ICM being the problem. I've had the exact same problem a few times now and it has always been the ICM. Car runs great until it just suddenly dies.
Steel
Report this Post08-28-2021 06:51 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
+1
Had this same issue on my first Fiero took a while to diagnose as I wasn't familiar with the platform back then. BVMotorsports helped me figure it out in Spinchat many years ago now~
