  ALDL Scan Tool Adapter
ALDL Scan Tool Adapter by Brent7088
Started on: 08-22-2021 04:49 PM
Replies: 5 (900 views)
Last post by: Brent7088 on 08-23-2021 01:39 PM
Brent7088
Report this Post08-22-2021 04:49 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone ever tried using this type of adapter to connect to your OBD2 scan tool? I purchased this one on ebay for around $8 and tried it out but didn't seem to work after plugging it in at the ALDL port (it flashed on for a hot second then no screen at all)...
IMSA GT
Total ratings: 253
Report this Post08-22-2021 06:35 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know if the ALDL connector can provide power out to that device.
Report this Post08-22-2021 07:22 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
98+% OBD2 scanners will Not work on OBD1 systems even if you find "Adapters." Worse can wreck the scanner and/or ECM trying that.
Very few if any "Pro Grade" OBD2 scanners might read OBD1 data.
Very few OBD1 scanners are "Universal" and read some to many car makers because ALDL plugs and more aren't standard across brands.
Old Snap-on and other High $ OBD1 scanners does this often w/ High $ "modules" to program them. Worse often need several "modules" to work w/ 1 brand of vehicles.
Is why many OBD1 scanners only fit one brand of vehicle.
So GM scanner won't work for Ford and others.
Lambo nut
Total ratings: 262
Report this Post08-22-2021 09:13 PM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.ebay.com/itm/AU...id=711-127632-2357-0
This is my goto for quick reads of obd 1 or 2.
Total ratings: 328
Report this Post08-22-2021 10:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
It looks like you tried to use an OBD2 scan tool on the ECM w C3 interface or in a stretch called OBD1. They have two entirely different data streams. I don't even know why they made those OBD1 to OBD2 adapters. They will not work.
Brent7088
Report this Post08-23-2021 01:39 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the replies everyone.. and thanks for the link Lambo - I may give that one a try. For now I'm gonna just try reading the flashes using the jumper procedure and see what codes it throws.
