  Trouble with Door Lock Rod Clip
Trouble with Door Lock Rod Clip by windex42
Started on: 08-23-2021 06:50 PM
Replies: 2 (553 views)
Last post by: windex42 on 08-23-2021 07:52 PM
windex42
Report this Post08-23-2021 06:50 PM Click Here to See the Profile for windex42Send a Private Message to windex42Edit/Delete MessageReply w/QuoteDirect Link to This Post
I removed the outer door skin, and I must have lost the door lock clip, the metal clip that holds the door lock rod to the lock cylinder.
I bought a replacement clip, Dorman part 75453 from autozone.
It appears to be similar to the part The Fiero Store sells.
I can't figure out how it's supposed to secure the rod though.
I see that the rod has a groove right at the tip that I assume the clip would catch on, but it just doesn't hold it in place.
The image (circled and labeled as #1) shows the clip slid up onto the tab, and the clip's retainer falls into the hole just like it's supposed to..
My clip fits like that just fine, but when I put the rod in, there's nothing to actually hold it there. the clip doesn't grab the groove at all.
I'm wondering if anyone has any insight on this, maybe there's another piece I'm not aware of?
I've also uploaded a photo of my rod and tab. I realize the rod is in the wrong hole
IMSA GT
Total ratings: 253
Report this Post08-23-2021 07:14 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Best I can do. Your rod goes through the lower hole and the clip slide over the grove that is cut in the rod as seen by the pink circle.
The clip holds itself on the lock mechanism by the indent in the green circle which clips into the top hole of the lock plate.
Compare my photo to your image 1 above. You can't see the backside of the clip but it looks like the one in my photo.
Edit, here's the backside from the factory manual:
[This message has been edited by IMSA GT (edited 08-23-2021).]
windex42
Report this Post08-23-2021 07:52 PM Click Here to See the Profile for windex42Send a Private Message to windex42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well thanks, IMSA GT,
That was a very detailed response complete with pictures I was unable to find myself.
It turned out that the problem I was facing was with the clip I bought.
The clip has the folded over piece of metal which creates the "Slot" for the rod groove.
The folded over pieces were touching/painted together.
I got them to spread a little, but then snapped the clip.
At least now I know what to look for when I buy a new clip!
I will consider this case SOLVED.
Thanks again, IMSA GT.
Nick
