  3800 NA PCM usable in a SC top-swap?
3800 NA PCM usable in a SC top-swap? by lou_dias
Started on: 09-08-2021 01:09 PM
Replies: 4 (355 views)
Last post by: ericjon262 on 09-09-2021 08:57 PM
lou_dias
Report this Post09-08-2021 01:09 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
So my 3800SC sledomatic car was a top-swap to the SC from an NA engine.
The PCM comes up as 1998 Pontiac Grand Prix GT ... not GTP.
The engine does not run perfect. Can this PCM be programmed to handle the SC addon? Or do I need to source an actual GTP PCM?
Report this Post09-08-2021 03:28 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The engine does not run perfect. Can this PCM be programmed to handle the SC add-on? Or do I need to source an actual GTP PCM?
If your PCM is the same as the PCM used on the SC engine, then the program for that model year 3800SC can be imported into your PCM. However, you state that the part number is different. The question is; does this part number just call out the same PCM with a different program or is the operating system protocol entirely different?
[This message has been edited by Dennis LaGrua (edited 09-08-2021).]
ericjon262
Report this Post09-08-2021 09:03 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
most of the OBD2 V6 PCM's have fairly extensive cross compatibility, FWIW, I've run a 3400, with L67 3800 programming. the software you are using will make a huge difference in what you can make happen with the car.
HPT?
DHP?
EFI live?
Tunercat OBD2?
if you're using DHP, I highly recommend finding "Tiny Tuner" and using a 2002 GP L67 bin file, as it has way more tables available to modify compared to almost any other OSID.
cognita semper
lou_dias
Report this Post09-09-2021 08:01 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
My dyno guy who is also a tuner uses Tunercat.
I'll try to get a part # for my PCM.
Seems to run fine at idle. Doesn't even throw any codes. Just seems to pull timing often when I get on the gas pedal.
I plan on converting it to a 4 or 6 speed eventually. I hate automatics...
ericjon262
Report this Post09-09-2021 08:57 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
tunercat OBD2 is fairly uncommon, that's not to say he doesn't have it, but it is very uncommon, as TC licensed the software to JET as the JET DST. I have it only because I bought a Roadrunner OBD2 years ago (man that was pricey...)
if you plan on converting to a manual, you need to set the transmission type in the PCM to 0 and wire in a "clutch anticipate switch" to pin C18(I think) for the PCM to get the most out of it. I'm surprised it's not throwing codes, the engine is consuming way more air than a NA 3800. For a car like a grand am, that never came with a 3800, I could see some merit to keeping the original OSID that came with the 3400, because it will communicate better with the BCM and other auxiliary components like the instrument cluster, for a fiero that has none of that, just get an L67 file( I would use an 02 grand prix file) and run it, it will be way closer to what you need out of the box.
cognita semper
