  is a 91 caddy 4t60 trans a direct swap ?
is a 91 caddy 4t60 trans a direct swap ? by Collector
Started on: 09-16-2021 11:50 PM
Replies: 13 (235 views)
Last post by: Collector on 09-25-2021 01:01 PM
Collector
Report this Post09-16-2021 11:50 PM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
4.9 caddy. is a 91 caddy 4t60 transmission a "direct swap" to where a th125 was ? (besides the vacuum line needed for the modulator?) Mounts ?? Axles??
Total ratings: 206
Report this Post09-17-2021 12:05 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Axles and mounts are different.
Vacuum port for the modulator is on the 4.9 throttle body.
You may or may not have to put a relay on the TCC brake switch to make the TC operate correctly.
The 4T60E is perfect for the 4.9 - and about the same amount of work as the 4T60.......
[This message has been edited by olejoedad (edited 09-17-2021).]
Collector
Report this Post09-17-2021 12:55 AM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
there will be NO COMPUTER
1Packrat
Report this Post09-17-2021 09:52 AM Click Here to See the Profile for 1PackratSend a Private Message to 1PackratEdit/Delete MessageReply w/QuoteDirect Link to This Post
You will need an early model 440t4 or 4t60 governor cap for the speedometer to work. That part is the hardest to find.
Caution with a Caddy transmission count the number of pins on the plug if it is 5 you are good if it is 7 it will not work.
[This message has been edited by 1Packrat (edited 09-17-2021).]
Collector
Report this Post09-17-2021 01:05 PM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
wouldn't a 7 pin be a 4t60E ?
Total ratings: 461
Report this Post09-17-2021 05:22 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was not aware that a 91 Caddy was even available with a regular 4T60. I thought they were all 4T60E (or F7, in the case of the Allante.)
Collector
Report this Post09-17-2021 05:35 PM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
could be mistaken on the year of the trans. 4t60 no "E"
Total ratings: 461
Report this Post09-17-2021 05:54 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gotcha. Might be an 89 or 90.
FWIW, I think the 3.4 DOHC also came with a 4T60, at least several years into the '90s. Came with an overall FDR of 3.42, IIRC. Not that that would be useful, in your case, if you're sure it was sourced from a Caddy.
[This message has been edited by Raydar (edited 09-17-2021).]
Collector
Report this Post09-17-2021 07:25 PM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
trans was bought as a Brand New Trans in the Orig Plastic Case from GM. by the owner of the car. I have not yet even SEEN It. Thanks
Total ratings: 259
Report this Post09-17-2021 07:52 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might find these helpful.
pmbrunelle
Total ratings: 63
Report this Post09-17-2021 11:54 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this Lou6t4gto with a new nickname?
Collector
Report this Post09-18-2021 12:13 AM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes, could not get my orig "sign in" to work anymore
Total ratings: 329
Report this Post09-25-2021 11:57 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Without an ECM, you will need to install a switch for the torque converter lock up solenoid to energize. Not the most convenient solution as you will need to switch it off every time the car is stopped with the engine still running or at low RPM use.
Collector
Report this Post09-25-2021 01:01 PM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 700r in my camaro, (any way it is the same setup ? as far as the tq conv ? i wire from the pressure switch to a toggle switch . with the switch ON it Only locks up in 4th Gear, it's not in 4th gear at a light. is the 4t60 not like that ??
