As covered in some PFF pages using many current Coolant Pressure Testers on Fiero have problems because has no room to use them with the hood on.
You can find Stant ST255 and ST270 that will attach to the Fiero Radiator on Ebay etc.
But also find Stant 12453 Cooling System Adapter, AKA GM 4 Cylinder System Testing Adapter
I see new ones cost as low as ~ $15 (plus S&H depending on "store.")
You can find it used and New on Rockauto and many more. If used make sure it has the rubber gasket.
Why?It's the adapter to fit the Thermostat housing.
Ignore Many Descriptions/Doc's by Stant and others only says will fit J and X body cars but in the manual for my ST270 does list Fiero L4 and V6.
I found one at a flea market today to see against T-stant cover to make sure they match.
⚠️ Warning: when you use this adapter... Your max pressure is limited by the radiator cap. If you try to reach Test PSI marked on most tester gauges 1. You can't reach that mark. 2. Your pushing coolant into the overflow tank then on the ground/floor.
Caution: Stant 12450 Cooling System Adapter, Truck Pressure Tester Adapter Kit, looks to have the adapter as well but without right thin gasket.
(Grayed out "A" size Rad Cap test part that come with many complete Stant tester kits on ebay etc.)
Notes:
If you find ST255 with bad hose, test "cap" or gauge... Can upgrade to work as ST270 with 12701 Update Kit. This upgrade may fit other old testers because made by Stant and rebrand for GM AC-Delco or based on Stant design.
If Gauge drops slow or fast and coolant doesn't leak... look for air leaks including in the tester. Tester has a check valve that gets dirty or wear out. To clean/fix that need to take apart "bottom" of the pump body.
While Stant has stopped making some testers or parts you can still get most or all because Stant made Millions of them over 50+ years.
I think you can use other testers w/ same adapter. Setup them as if run on Fiero radiator neck but connected to the adapter. That way you could get "universal" tester from loader tools at AZ etc. and only buy the adapter.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 04-30-2024).]
