Ok, I got the car to crank. It seems when someone switched over from the original manual trans in the car to an automatic
instead of moving the pin in the C500 to A4 for the wire running to the neutral switch they just reconfigured the wires closer
to the neutral switch.
My problem now is that the car won`t start.
Per this diagram there is suppose to be a Pink wire running from the C500 to the ICM for a 12V feed.
My harness, which is an Ignition Technologies, does not have a Pink wire in the harness from the C500
It does have these two small circuit boards (one which is fried) in the vicinity of the C203 plug.
They are labelled vats.
On other social media sites nobody seems to know what the small circuit boards are, leading me
to believe that nowadays most people just program the vats off in the computer and maybe those
circuit boards aren`t necessary.
And, since there seems to be no 12V feed wire for the ICM in the C500 harness it must originate from
somewhere else.
I just need to get 12V to the ICM somehow and was looking for ideas.
Thanks
.jpg)
