  Need some help understanding my exhaust manifold
Need some help understanding my exhaust manifold by FranklinTurl
Started on: 10-15-2021 05:19 PM
Replies: 2 (826 views)
Last post by: IMSA GT on 10-15-2021 08:06 PM
FranklinTurl
Report this Post10-15-2021 05:19 PM Click Here to See the Profile for FranklinTurlSend a Private Message to FranklinTurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
**1984 Pontiac Fiero SE 2m4** I've been rebuilding this Fiero and I have decided to replace the exhaust manifold, i ordered a new one and im a bit confused. the small little pipe that comes off the back of the exhaust manifold (circled in picture of manifold on table) I have learned (correct me if I am wrong) is called the heat exchange pipe?? I took a look at my current one in the engine and it is a lot larger and is currently connected up into the air filter cleaner housing. However, I have seen other engines with a heat pipe that connects into that spot on the filter housing and then goes down into the exhaust below. So im trying to figure out: A. what is the little pipe hanging out of the exhaust manifold B. Does it need to connect into anything? C. and if it does NOT connect into anything then where does the outlet on the filter housing where it is currently connected into, supposed to connect to?
Sorry if its a bit confusing, this is my first project car and I'm learning as I'm going so not quite sure what everything is called yet. Thank you for any help! its much appreciated!
[This message has been edited by FranklinTurl (edited 10-15-2021).]
Report this Post10-15-2021 06:50 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like that replaces the stock one that went down below. The one I saw from below simply had a metal shield around the exhaust pipe then a flexible hose up to the filter canister. I always heard it called a heat riser. It lets the warm air off the exhaust rise up and enter the filter canister through a thermac valve in the filter canister. Its purpose is to provide warm air to the throttle body to prevent icing, until the engine warms up.
IMSA GT
Total ratings: 250
Report this Post10-15-2021 08:06 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
As mentioned above, you attach the pipe from the air filter housing to that pipe on the manifold. It should fit fine.
