  CRACKED EXHAUST MANIFOLD
CRACKED EXHAUST MANIFOLD by eti engineer
Started on: 10-26-2021 03:01 PM
Replies: 22 (619 views)
Last post by: eti engineer on 11-06-2021 09:02 AM
eti engineer
Report this Post10-26-2021 03:01 PM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
The saga of my Fiero rebuild continues...
I was planning on doing my brakes today so I can get my Fiero inspected and on the road, so I can take it back to the engine builders and have them fix the leaking rear seal. I started the engine early this morning while it was still dark in my garage and thought that it sounded differently than usual. So I did some looking. In the process, I manually operated the throttle by hand while listening to the engine. When I did, out of the corner of my eye, I thought I saw some flame. So I did it again and sure enough. See the photo below. I could see it along the exhaust on cylinder #6. I got my trouble light and took it over to the spot and from the picture below, you can see what happened. The exhaust manifold cracked along the weld.
A used manifold costs 350 dollars from the Fiero factory. Not a problem, but I don't like spending that kind of money for a used manifold. The rear one is 250 dollars. Anyone in here have a set of old manifolds for an '88 GT they'd like to sell me?
Has anyone ever had one re-welded and had any success with it? This is getting frustrating. I am thinking no more mid-engine or front-wheel drive projects for me. Front engine, rear-wheel or four-wheel drive projects or motorcycles, all pre-smog for me anymore.
[This message has been edited by eti engineer (edited 10-26-2021).]
Xenoblast
Report this Post10-26-2021 03:18 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, also id port the headers to gain 8hp while your at it.
heres what mine looked like:
The process isnt terrible, I could have done it in a weekend if i had all the parts right away, with the header welded soon after, and if 2 studs werent seized.
eti engineer
Report this Post10-26-2021 06:36 PM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
What am I looking at in your photo? I think the piece I need to see is out of the top part of the picture. I am just hoping I can pull the exhaust manifold with the engine in place. It appears that I can. I think there is enough room between the firewall and the engine. If anything, I think maybe I can undo the dogbone and pull the top of the engine back a little to give me some more room. I sure thought that I would have the car back on the road by the end of this week with all work done. Oh well....
Oh, I see. The blue tube is the one that goes to the fresh air intake, right? The totally cracked portion is your exhaust manifold? What a mess!!!
[This message has been edited by eti engineer (edited 10-27-2021).]
cvxjet
Report this Post10-26-2021 07:29 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are two Fiero V6s in CA junk yards; One in Sacto (10/25) and one in Fairfield (10/6) So go grab some spares! (I should take this advice)
You can check on "Row52" for cars in the Junk yards......usually even have a picture.
[This message has been edited by cvxjet (edited 10-26-2021).]
Xenoblast
Report this Post10-26-2021 07:33 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is (or was) my crack in my headers. You asked if welding cracked headers works, it has worked for me for like 3k miles now. We will see how long it lasts, but I now live in a less rainy state so it shouldnt crack any time soon.
Heres a picture of them out, probably should have sent this first.
Also I pulled them off with the engine in the frame, just need small hands and hope that no studs are siezed
[This message has been edited by Xenoblast (edited 10-26-2021).]
Total ratings: 465
Report this Post10-26-2021 08:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately, there's no guarantee that the exhaust manifolds...
a) haven't already been removed.
b) (if still on the engine), aren't cracked as well.
pmbrunelle
Total ratings: 63
Report this Post10-26-2021 08:10 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should probably read through this thread:
https://www.fiero.nl/forum/Forum2/HTML/144447.html
The thread starter has Sprint headers, but I think the discussion remains applicable to the stock Fiero pieces.
Regarding engine placement in the chassis, poor exhaust manifold design can happen regardless of where the engine is located.
eti engineer
Report this Post10-27-2021 09:21 AM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man, your manifolds make mine look good!!! Thanks for the good news. It looks like I can pull mine, too. It will be a little tight on the front one, but I just recently had my engine on a stand after the rebuild, putting the exhaust manifolds back on it, so my studs will not be frozen into the engine. That is one advantage I have. I don't have small hands, though. I wear a size 14 ring!!!! (LOL) I am going to pull both of them and take a really close look at them. I have another front manifold on the way -- used but intact -- so I will probably put that one on the engine and get the old one welded as a spare.
eti engineer
Report this Post10-27-2021 09:25 AM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
eti engineer
Member since Mar 2017
Thanks for the info. I live in the Central Valley, Northern CA. Sacto is only 45 minutes away and Fairfield is about the same. Are these "Pick and Pull" sites, or have they already been pulled? Thanks for the info!!!
cvxjet
Report this Post10-27-2021 11:18 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are Pick-&-Pull yards, so you have to pull 'em yourself......Bring a blow torch, 10 lb sledge and some dynamite (Just kidding)
eti engineer
Report this Post10-27-2021 01:33 PM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know what you mean. I had to pull some stuff for my 2001 Dodge Dakota and it was literally as you say!!! Thanks for the reminder...
Total ratings: 328
Report this Post10-27-2021 08:10 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Used may not last very long. You should be able to build a new one or repair one for far less than that. IMO, that price is really exorbitant.
eti engineer
Report this Post10-28-2021 10:07 AM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree that the price is exorbitant, but it's only money. I'll make more. I'm retired and rich. I'm gonna sell the Fiero once I am done. I have done front engine, front wheel drive, rear wheel drive, four wheel drive, mid-engine, rear engine and motorcycle projects now. I am going back to front engine, rear or four wheel drive, pre-smog vehicles or motorcycles. Much easier to work on. I don't think I will ever touch a mid-engine vehicle again.
[This message has been edited by eti engineer (edited 10-28-2021).]
reinhart
Report this Post10-31-2021 04:10 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
It seems like with so many Fiero owners doing engine swaps, there should be a plethora of used engine parts floating around that they wouldn't be so expensive. $350 should get you a complete dressed engine including manifolds!
Daryl M
Report this Post11-01-2021 02:22 AM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a good pair. $100+ shipping. PM me.
eti engineer
Report this Post11-01-2021 04:12 PM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I PM'ed you, but I don't see evidence of its having gone out to you. Did you receive my PM? Thanks....
WKDFIRO
Report this Post11-01-2021 11:12 PM Click Here to See the Profile for WKDFIROSend a Private Message to WKDFIROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also check your mounts, specifically the torque strut (up on top) and the forward transmission mount. If they are bad than the engine movement pivots right at the point of the manifold cracks.
ZaraSpOOk
Report this Post11-02-2021 01:01 PM Click Here to See the Profile for ZaraSpOOkSend a Private Message to ZaraSpOOkEdit/Delete MessageReply w/QuoteDirect Link to This Post
15-20 years ago so many guys were upgrading their 2.8 to something else you could get an engine free if you came and got it ( after they spent a few months trying to sell it)
I only wish I had had the space to store one ... 2 or 3
I sold a pair of exhaust headers for $60 including the shipping just b4 Xmas, cost me $19 to ship
Daryl M
Report this Post11-03-2021 01:08 AM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got 2 emails. Was that you? I sent photos.
Total ratings: 465
Report this Post11-03-2021 01:27 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
A_Lonely_Potato
Report this Post11-04-2021 10:14 AM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
eti engineer
Report this Post11-06-2021 08:59 AM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I pulled the cradle out, I re-did the motor and transmission mounts. They are all new. The old front transmission mount was broken in half. Maybe the manifold was cracked before I did this work and I didn't notice it in the rebuild. The rest of the exhaust system is new, all the way to the tips. One thing the new exhaust system does that the old one didn't is, as it's warming up, the metal makes a snapping sound. Same as when it is cooling down. Cheap Chicom metal that is going to give me trouble in the future?
eti engineer
Report this Post11-06-2021 09:02 AM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
eti engineer
We're square now. It was me, but you already know that after our phone conversation (LOL!!!). Thanks for the comeback and I will be looking forward to getting the manifolds, but not to having to do the replacement...
