  Broken lower control arm mounting bracket
Broken lower control arm mounting bracket by Derrick Boss
Started on: 11-24-2021 11:38 AM
Replies: 0 (586 views)
Last post by: Derrick Boss on 11-24-2021 11:38 AM
Derrick Boss
Report this Post11-24-2021 11:38 AM Click Here to See the Profile for Derrick BossSend a Private Message to Derrick BossEdit/Delete MessageReply w/QuoteDirect Link to This Post
The lower control arm mounting bracket on the driver's side has broken loose from the frame. That same bracket has also split in half at the bottom. Rather than welding the bracket back in place, I am wondering if there is a better solution. These brackets are thin and this is the second time it's broken away from the frame. Ideally, I'd like to fabricate a thicker bracket and weld it to the frame. Has anyone had this problem and what is the best way to deal with it? Is there an aftermarket (beefier) bracket? My concern is simply welding the existing bracket will be an ongoing event.
[img]https://images.fiero.nl/u serimages/Derrick%2520Boss/lower%20control%20arm%20mounting%20bracket%201.jpg[/img]
[This message has been edited by Derrick Boss (edited 11-24-2021).]
