Hello everyone.
I have a very annoying problem with my fiero 88gt clutch bleed.
When, I bleed the hydraulic system of the front and rear clutch system (master and salve cylinder) after 30km the problem returned with air in the system.
What could be the problem, according to you?
The symptoms are that the gears don't shift at all.
The master and slave cynlinder is brand new from Rodney Dickman.
I bleed the front with the kit, then I've bleeded the rear with a pipe and oil and a
Jar to expel the air.
Then concerning the slave, I remove the rear bleed screw I push the mechanism of the rod then another person tightens and I let go and the problem disappears for a while then comes back ...
What do you think ?
Could this be a bad bleed?
Thank you in advance for your responses.
[This message has been edited by zobari (edited 11-28-2021).]
