  Fuel/Temp gauge wiring
Fuel/Temp gauge wiring by 4thfiero
Started on: 05-16-2022 06:25 PM
Replies: 5 (245 views)
Last post by: olejoedad on 05-18-2022 02:10 PM
4thfiero
Report this Post05-16-2022 06:25 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys,
I replaced my stock fuel/temp gauge with an aftermarket Fuel gauge bcc the stock one was reading incorrectly. I got Jack to fix and recalibrate it. Now im installing the stock one back in my gauge cluster.
Issue im having is, im not the one who installed the aftermarket one in the first place, there was some modification to the wiring harness...so im not 100% sure which wires are supposed to go where...below is a picture of the wiring harness and aftermarket gauge. Can someone please tell me which wire goes to which posts on the stock gauge?
Thank you in advance!
Total ratings: 206
Report this Post05-16-2022 06:39 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That appears to be a lighting plug for a trailer, so there is no way to tell what goes where from your picture.
Post a picture of the other part of the trailer plug showing the Fiero wires hooking to the trailer plug wires.
Or, if you want it done correctly, you can reattach the proper wires to the plugs that go into the instrument cluster. I can direct you to the proper wires and terminals.
That is the preferred way to reinstall the stock gages.
4thfiero
Report this Post05-16-2022 07:22 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah crap...i wasnt aware that this plug was not stock either, they must have added it...the car is in a different lcoation. Will get a picture once I go back. Thanks for the help!
Total ratings: 206
Report this Post05-16-2022 08:10 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to help.
4thfiero
Report this Post05-17-2022 07:34 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey! I finally got my photos. I hope they are clear enough…
Total ratings: 206
Report this Post05-18-2022 02:10 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The most expedient way to fix your problem is to reattach the cut wires from your harness to the plug that is installed in the instrument cluster housing.
The recalibrated gage can then be plugged into it's location in the cluster, the plug reinstalled to the cluster housing, and everything should work as it should.
The wires coming out from under the dash are the ones we will be hooking back up to the plug.
The plug has numbers on it.
Black - Ground - #11
Pink - 12v IGN - #9
Light Green - Temp Signal - #13
Gray - Illumination - #3 or #15 (whichever one of the two gray wires was used is where the repair should be made)
Hope this helps you get it fixed.
[This message has been edited by olejoedad (edited 05-18-2022).]
