  setting valves on 88 2.8- how?
setting valves on 88 2.8- how? by 1966charger
Started on: 06-02-2022 12:26 PM
Replies: 3 (256 views)
Last post by: Dennis LaGrua on 06-03-2022 12:14 AM
1966charger
Report this Post06-02-2022 12:26 PM Click Here to See the Profile for 1966chargerSend a Private Message to 1966chargerEdit/Delete MessageReply w/QuoteDirect Link to This Post
what is the best method to adjust the valves after a valve job?
Report this Post06-02-2022 01:13 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Follow the instructions in the Factory Service Manual.
The determination of the initial 'zero lash' point is critical before tightening the nut above the rocker.
[This message has been edited by olejoedad (edited 06-02-2022).]
Total ratings: 463
Report this Post06-02-2022 04:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
As Joe has stated, finding "zero lash" is critical. I suspect a lot of people screw this up. I explained how I went through the process of setting valve lash on a 2,8 Here.
Report this Post06-03-2022 12:14 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Easiest way and most precise way. Mark balancer with chalk into 4 equal 1/4 turn segments. With plugs removed and all rockers in place but loose, put engine on TDC timing mark. Take out all the slack on each push rod by moving them up and down with your fingers until no more movement is felt. Rotate engine 1/4 turn and do this again. Then again at another 1/4 turn continuing to take the slack out on each cylinder on each 1/4 turn for two complete rotations of the crankshaft. Now go to each rocker bolt and tighten each 1 1/2 turns. Done
