  Compatible EGR Solenoid FOUND
Compatible EGR Solenoid FOUND by WonderBoy
Started on: 06-11-2022 02:12 PM
Replies: 23 (3839 views)
Last post by: Raydar on 11-13-2025 12:27 AM
WonderBoy
Report this Post06-11-2022 02:12 PM Click Here to See the Profile for WonderBoySend a Private Message to WonderBoyEdit/Delete MessageReply w/QuoteDirect Link to This Post
While looking for a possible minor vacuum leak after I installing OEM Cruise Control functionality in my 87 GT, I was having a suspicion about the EGR solenoid/valve. Now, I'm not getting any SES codes (CODE 32) at all, and I did the forum repair on this device 6 years ago (no ohms, broken coil wire @ solder post along with adding RTV to seal some areas as a preventative measure), but I was getting some minor air passing through it while doing tests as recommended in the 87FSM flow chart. So I decided to open it up again. Even with the RTV I put at various water entry points, the coil was rusted over sooo bad and the shaft going into the air filter looked like a 100 year old rusty nail, that it was gonna soon eventually die on me and short itself out to the metal housing then to the mount then to the engine. Off to the Internet and PFF.
The good news is, there is an EGR solenoid available (NOS for other 80's vehicles) that is a perfect match for our 2.8 V6's (2.5 also?). Since most of us longtime Fiero lovers are pretty good DIY'ers, all you have to do is transfer 3 (three) parts from the old original Fiero EGR solenoid and install on the new.
Below is the info and what needs to be done. First off, the part numbers.
Fiero Original (unicorn, good luck finding one):
ACDelco 214-361
GM 10038324
Near EXACT replacements:
ACDelco 214-303
GM 25519958
(Was available on MANY 80's GM vehicles, this post is gonna be about this one)
--->>>As of 6/11/2022: eBay, I currently see over 30 of them NOS. 7 under $120, and one seller has over 20 but cost $350+<<<--- Search both ACDelco and GM part numbers.
As far as junk yard pulls, these are compatible vehicles that you can probably get a decent one.
ACDelco 214-305
GM unknown
(Edit: GM 25519960
(Edit: Standard Motor Products VS5
--->>>As of 6/11/2022: eBay, I currently see over 20 of them. Price ranging from $65 - $140<<<---
(Same as above but includes sensor-switch/solenoid mount)
ACDelco 214-366
GM 14089438
Standard Motor Products VS16
(1985-1989 Pontiac Firebird and 1985-1989 Chevrolet Camaro, this one includes the jumper hose and the 3 inlet/outlet pipe setup just like on the Original Fiero EGR solenoid. This one is another unicorn and all you'd have to transfer to this one from the Fiero is the mount and air filter.)
Let's begin. This is just a minor how-to. Most other info can be found in these links (and others) already on the forum.
(CODE 32 answers. dialup warning pics)
(How I repaired my EGR Solenoid and eliminated my Code 32)
(EGR Solenoid Easy Economical Replacement)
So here's whats on 'My Plate'
(These 2 pictures are from my old coil and metal housing)
PUSH the coil out of the metal case entirely by applying pressure to the shaft sticking out, just enough to have the plastic tabs exposed and seal. Then push back into the metal case.
Put the block-off metal disc and spring back in.
Now, when the electromagnet coil is installed in the metal case/housing, I'm willing to bet a special press was used at the factory to put equal amounts of pressure on all 8 metal tabs. I found that after I was putting this one back together the first time, I had a small leak when I used a section of silicone hose and blew into it and applied suction while plugging the other 2 using 2 fingers wearing a rubber glove. I would do this several times as I was bending the metal tabs. I found that by pinching them across from one another was best. Took me the usual, 3 times, taking off putting back on to get it right.
The other way, I would always get a minor leak somewhere around the seal or where the 3 pipe adapter mates onto the solenoid housing.
I've been known to over-think things from time to time, but It's EXTREMELY advised to waterproof and seal this as you reassemble. In other PFF threads related to CODE-32 some have PLASTI-DIPPED theirs instead of using 3M Weatherstrip Adhesive or silicone RTV. I didn't have any PLASTI-DIP, so I used what I had. When I repaired my original EGR solenoid 6 years ago, I see where I went wrong and why it started getting more rusty then it was when I first took it apart. Originally I only put sealant where (1) The 2 wires go into the metal housing to the coil (2) Around the metal housing where the air-filter dead-stops and the wires come out under the plastic hump (3) All around the square of the sensor/switch/filter (4) Where the 2 wires go into the sensor/switch/filter enclosure. This go around I added sealant to go around where the coil goes into the metal case as shown in the pictures above (rusted inside metal coil housing picture).
Why GM decided to put this device directly below the coolant/thermostat house, I'll never know. From the vents above the battery (water), the engine coolant/thermostat housing )coolant/water), engine heat (plastic degradation/contraction), you should seal it some how.
Feel free to let me know of any errors, or other suggestions to contribute to this problematic component that may become extinct.
I'm no mechanic, just a guy who likes to tinker.
{Edited to add other compatible part numbers and eBay availability}
Curtis
1987 Pontiac Fiero GT:
<Drives like a Go-Kart, handles like a roller coaster>
[This message has been edited by WonderBoy (edited 06-11-2022).]
freedom0226
Report this Post05-21-2023 10:45 PM Click Here to See the Profile for freedom0226Send a Private Message to freedom0226Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is amazing im going to try this out. Ac delco 213 305 is what I found on ebay.
DRMII5388
Report this Post06-22-2023 09:50 AM Click Here to See the Profile for DRMII5388Send a Private Message to DRMII5388Edit/Delete MessageReply w/QuoteDirect Link to This Post
What, it didn't work with a tee and hose extensions?
BHall71
Report this Post06-22-2023 09:38 PM Click Here to See the Profile for BHall71Send a Private Message to BHall71Edit/Delete MessageReply w/QuoteDirect Link to This Post
And ogre's reply saying why it won't work in 5, 4, 3, 2.....
[This message has been edited by BHall71 (edited 06-22-2023).]
WonderBoy
Report this Post06-22-2023 09:44 PM Click Here to See the Profile for WonderBoySend a Private Message to WonderBoyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The point was to keep everything looking original without modification. Painting optional.
Report this Post06-26-2023 12:34 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats what I believe. Functionality should be the primary objective. The slightly different look of using longer hoses and a T connection should not be a big deal.There is talk about preserving the original appearance but painting the unit a bright blue is not original.
WonderBoy
Report this Post06-27-2023 12:00 AM Click Here to See the Profile for WonderBoySend a Private Message to WonderBoyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, just WOW.
Why do these solenoids die and fail?Water leaking in. Thermostat housing/cap drip/coolant spill. Rear deck vents throw water on the belt throwing more water on it (yes, some of us DO use our Fieros as daily drivers and not just wipe them with diapers so they get driven in rain and snow). It's mount location was a poor location. You will want to seal this new one up if you want LONG LASTING FUNCTIONALITY... and in the process use the old hardware ('Tee' and filter) if you don't have access to another "tee and hose extensions".
We all aren't gearheads and grease monkeys that have that extra stuff in our back pockets or garages.
[This message has been edited by WonderBoy (edited 06-27-2023).]
Forrest
Report this Post07-12-2023 11:30 AM Click Here to See the Profile for ForrestSend a Private Message to ForrestEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am just posting to confirm that this corrects error code 32. Plug and play...no mods. Toss the old one and plug in the new one. All sorted.
The car has had this stinking error since I bought it. I have tried a few different solenoids and it remained.
Shortly after the car warms up boom the light popped on.
I ordered the following from ebay:
OEM VS5 EGR NEW Valve Control Solenoid/Motor
$67.75
Interchange Part Number
214305, 25519960
BUICK CENTURY 1984-1985
BUICK ELECTRA 1985
OLDSMOBILE 98 1985
OLDSMOBILE CUTLASS CIERA 1984-1985
Thank you to the OP for letting us know!
pokeyfiero
Total ratings: 306
Report this Post03-29-2025 09:02 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm just bumping this to bring to attention if any new developments have been achieved.
buddycraigg
Total ratings: 478
Report this Post04-01-2025 12:46 AM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
just jump the wires people.
The computer will "think" the EGR is doing its job, and everyone will be happy.
steve308
Total ratings: 58
Report this Post04-01-2025 12:15 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Need one of your fine videos on the EGR wire jump and vacuum line delete-- For off road and racing purposes only of course.
Report this Post04-01-2025 03:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removing the EGR on my Fiero(s) is not something I wish to do... but for anyone who does wish to do so, I suspect your engine will not be "happy" unless you also take the additional step of having a re-programmed (EGR deleted) PROM installed. Plenty of threads in the forum cover this.
Total ratings: 200
Report this Post04-01-2025 06:51 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
The only problem with that though is that the EPROM in the ECM is actually programmed to account for EGR gasses... so if you disable the EGR, your fuel maps are going to be off. EGR... I'm not really a fan, to be honest... it does have some benefits, like keeping the piston tops cooler, etc... and even improving fuel economy while cruising, but I really dislike all the "crap" it puts in the intake.
But disabling it isn't ideal... you need to get a new PROM that's programmed to account for a disconnected EGR so you have the proper fuel mapping without it.
buddycraigg
Total ratings: 478
Report this Post04-01-2025 10:56 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't count how many years I drove my 85 without any negatives that i could see.
I've done it to many customers cars, and they didn't mention any change in performance.
Mickey_Moose
Total ratings: 145
Report this Post04-02-2025 03:53 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the EGR is disabled in the EPROM wouldn't it just use the EGR off fuel map?
Additivewalnut
Report this Post04-14-2025 11:20 AM Click Here to See the Profile for AdditivewalnutSend a Private Message to AdditivewalnutEdit/Delete MessageReply w/QuoteDirect Link to This Post
That got a hearty laugh from me. I swear ogre has some good info but he's so negative all the time.
1985 Fiero GT
Report this Post04-14-2025 12:51 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
He did and was, he's stopped posting on this site for quite some time now, to many people ignoring him or making fun of his legalism, so he just disappeared, then got mad when people were contacting him more directly, making sure he was still alive.
cartercarbaficionado
Report this Post04-14-2025 03:35 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
no he got mad that someone was sent to his house and the dude went around harassing his neighbors about ogre repeatedly. before we bash lets make sure we all have the facts right so at least we can say we tried to be correct
Report this Post04-14-2025 03:50 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You appear to have missed the drama. Catch up here... the Ogre
I defended Ogre plenty of times in the past when people got pissed off at his gruff manner... but he unfortunately crossed the line big time. Whether it was due to the onset of dementia or another stroke or whatever... he's no longer welcome here.
1985 Fiero GT
Report this Post04-14-2025 04:05 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not bashing, personally I'm sad he's gone, it was a reasonable response to his sudden disappearance, especially since it was soon after another forum members death and the ogre has had several close calls medically, for people who knew him to check up on him in person, after trying all the digital channels first. I'm sad that he felt noone cared about what he says, I'm sad he's gone, and the forum cared enough to try to make sure he wasn't dead, rotting alone, but he didn't like that, even if it was "reasonable".
Additivewalnut
Report this Post04-15-2025 10:43 AM Click Here to See the Profile for AdditivewalnutSend a Private Message to AdditivewalnutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whoa. That was.... an unpleasant read. I can't believe that happened last August. I swear I had him telling me that my Grand Am swap was a **** idea fairly recently. Hope he's doing well regardless. Dude was an ass but everyone deserves to be happy.
MarkS
Report this Post04-15-2025 02:30 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I'm sure he came up with the Ogre handle & Avatar himself, no? (Or maybe an ex-wife haha!) kinda like a shot across the bow.
Total ratings: 200
Report this Post11-12-2025 02:06 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I can't say... I've never disabled the EGR in any of my builds. My assumption is that there is only one fuel map... and things like the EGR or other sensors either increase or decrease other variables as it goes through the loop.
For my V6, I'm looking to install the FAST EZ-EFI 2.0 system... one of these days. We're working on my daughter's cars while she's still in school. I have her for 1.5 more years. Then I'll work on my car. But with the FAST system, it doesn't really care or know whether or not you have an EGR. The goal isn't to eliminate emissions or anything like that, but the newer system will just operate better, and more efficiently... so it doesn't really need the EGR. I'll probably still have it installed, though it'll never be activated.
One thing I do find interesting though... the 84-86 4cyl Fieros don't have any kind of vacuum solenoid. Merely... the EGR engages and disengages based on vacuum. So, it expects it all the time. What specifically does the vacuum regulator do on the V6 Fiero that it needs a vacuum regulator? Why couldn't they have merely attached the EGR in a similar fashion to how the 4 cyls were? And... would it not function the same?
Total ratings: 463
Report this Post11-13-2025 12:27 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are indeed two fuel tables - and two ignition timing tables. One set for "EGR ON" and one set for "EGR OFF".
The "EGR ON" runs much leaner, and with much more spark advance.
The recycled exhaust gas is basically inert, and helps to cool what would otherwise be a "way too lean, and way too advanced" combustion cycle. Way simplistic, but that's the nuts and bolts of it.
People who jumper the EGR solenoid to trick the ECM can run the risk of burning pistons. It doesn't always happen, but it absolutely can.
When I was at the Fiero Factory, I saw several engines that had holes in the pistons in cylinders 2 and 3. Seemed to be the pattern. (I'm not saying that's why, but it would figure.)
The EGR on the V6 and the 4 cylinder (even the 87-88) run off of "ported vacuum". The V6 solenoid helps to control it more precisely, and also offers diagnostics, in the form of the dreaded "Code 32". I have no idea why they didn't think diagnostics were necessary on the Duke.
When I thought I had a bad solenoid, I thought about just running the EGR valve straight to the throttle body vacuum port, in order to pass emissions.
As luck would have it, the problem ended up being elsewhere. (I had a ported throttle body, and it affected the amount of vacuum available at part throttle. IIRC, I had to swap a stock throttle body back onto the engine, to "see" enough vacuum to make the EGR work.) This is from memory. And I've slept since then.
Another little bit of probably useless trivia...
When the EGR is "moderated", by the solenoid, the vacuum is just vented to the atmosphere through the fitting on the end of the EGR solenoid - the one that connects to the tube from the firewall. If you block that fitting, then full ported vacuum is applied to the EGR valve, regardless of what the solenoid is doing.
[This message has been edited by Raydar (edited 11-13-2025).]
