Don't count on that Even tho they work and give right pressure...
I've some intermittent problems that act like something gets hot and won't run. I had spares so slowly swapped many electric parts and still have same problem...
Finally made 15psi (Duke only need 9-13PSI) Fuel Gauge w/ long hose and problem is no pressure even tho pump runs.
People know if drop the tank for any reason just replace the pump and J30R10 hose so yes I got a new pump,
I don't think the pump is dead but...
Hose at top had rust where hit metal feed tube likely loosing some pressure.
"Sock" at bottom of pump was completely F'd. Bad dirt plus was whatever fabric was "rotten" too and failed where has metal part to mount to pump. I think some crap got thru there causing low/no pressure intermittently even tho pump runs. Restricted Fuel Flow for any reason can make FP to run hot too.
I also clean the plug at the "Flange" at top. Mine is ok. That is a plug and socket Not an 1 piece pass thru thing. (Someone found replacement but can't find the post.)
Clean C502 too. Note is a Weatherpack but Not a Generic shell. If pins are iffy can replace them.
Use Plastic Friendly electric cleaner. Cleaner/Lube for externals like C502.
Cleaned Fuel Gauge sender... You can carefully pry up 1 and loosen other 2 "pins" holding it together to clean. I just use "scotch-brite" to knock of loose crap. Is a spring inside to help ground the arm that maybe gone causing problem for many people. When you reassemble make sure all "pins" are tight. Sender should read near 0Ω empty 90+ Ω full. Caution: When tested by hand may drop out when moved because may load sideways and not notice. Note: If this has burn out, Gauge has problems and will fry replacement too.
Dropping the tank... The 2 nut for the straps are locking type and will not "spin" off or on. Clean the Threads before removing them. Dremel w/ wire brush (flat type) save time.
