| quote | Originally posted by phil_d:
Here's a video that might help. https://youtu.be/pK8oa1MNl38 Would this make it a button issue? I'm new to Fiero ownership so this is all new to me |
It is hard to see much in your video. Did you watch my video? When pulling the lever up it should ratchet to engage. You then pull it all the way straight up, [i]hold the button in the whole time you are releasing it ]/i] so that it pushes out the curved bottom out and that curved bottom should release as you are bringing the lever back down.
You could always pull your brake and see if it ratchets up and then releases back down. If it does, then your cable is frozen. I my opinion, it is probably the easier task then trying to mess with the cable first... but opinions are butts, everyone has one...
Watched your video a couple more times. When you have the lever all the way up and push the button, it may not be extending far enough. You can try pushing down on the little plate it pushes against and see if that helps release it. If it does, the the button doesn't push out far enough.
[This message has been edited by MulletproofMonk (edited 06-19-2022).]
