Update System
  Where to hook-up hose to empty fuel tank?
by imacflier
Started on: 06-30-2022 09:17 AM
Replies: 8 (479 views)
Last post by: sanderson231 on 07-05-2022 02:20 PM
imacflier
Report this Post Click Here to See the Profile for imacflierClick Here to Email imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, Guys,
I need to drain my fuel tank prior to dropping it. Since I am old, fat, and disabled, I REALLY want to avoid crawling under my '88 GT as much as possible!
I know the traditional place to hook up a discharge hose is at the fuel filter, but that requires crawling under the car.....TWICE!
There just has to be somewhere on the top side of the engine that I can hook up a discharge hose and let the fuel pump do it thing.
Please tell me the easiest point to hook up that discharge hose! (Extra points for pics or FSM drawing references!)
TIA,
Larry
imacflier
Hi, Guys,
OK, in looking at the 22P I think the fuel feed line running from the fuel filter starts as a pipe attaching to the output of the fuel filter, becomes
a 3/8" rubber hose, running to the engine (it is not clear how the hose terminates)
I haven't physically looked yet (tomorrow's task), but is it reasonable to cut the hose somewhere before the schrader valve, hook-up my fuel
discharge line, empty the tank, and SPLICE the original hose where it was cut???
Sounds like it might just work to me, whatcha all think?????
TIA
Larry
Total ratings: 465
Report this Post Click Here to See the Profile for PatrickClick Here to Email PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's a thread six positions below yours (as I type this) that appears to be somewhat the same topic.
greenturnedblue
Report this Post Click Here to See the Profile for greenturnedblueSend a Private Message to greenturnedblueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't know how you would splice the rubber lines back together after you cut it but seems like a bad idea
Total ratings: 570
Report this Post Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You Don't Cut Lines.
Get under the car and Remove rubber hose.
Just splice rubber to "Siphon" hose using any tube scrap etc.
Or if can reach clamps on tank side rubber then remove rubber and attach new hose to tank.
"Siphon" hose can be almost any hose but expect that will be crap because often gas "eats" it.
Small Hose clamps "nuts" are 1/4" not metric. (Bigger clamp "nuts" are 5/16" not metric.)
Problem is tank side clamps are installed before installing the tank in the car and "nuts" are often pointed so hard to access because too close to frame to use most ratchets. Often even hard to access w/ small wrench.
If tank is under ~ ¼ don't bother emptying in the car. 2-3 gallon won't spill and isn't very heavy.
fierosound
Total ratings: 286
Report this Post Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageClick Here to Email fierosoundSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
IF fuel pump is still working, this is what I have done.
Do this after engine has been off for a few hours, so fuel pressure has dissipated.
Remove fuel rail schrader valve core (same as tire valve stem) where you'd normally connect a fuel pressure tester.
Then slip a rubber hose (5/16" ID I think) over the threaded fitting with a spring hose clamp to secure it. Run hose to your gas container.
At the ALDL connector next to the cigarette lighter, jumper power from the cigarette lighter to the "fuel pump test" terminal to run pump.
Remove jumper once fuel pump starts sucking air. Remove hose and reinstall schrader valve core before you forget and lose it.
[This message has been edited by fierosound (edited 07-28-2023).]
greenturnedblue
wouldnt you also need to depress the little pin inside the valve to get it to open?
Total ratings: 465
Not if it's been removed.
...reinstall schrader valve core before you forget and lose it.
sanderson231
Report this Post Click Here to See the Profile for sanderson231Click Here to Email sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
greenturnedblue, you use a special tool to unscrew the core of the schraeder valve which has the pin.
I have run AN hose for fuel lines on engine swaps I have done. You can can unscrew the fuel hose at the connection coming from the tank at the lower fire wall. Summit sells an o-ring 16mm power steering adapter (<$10). The o-ring end will screw into the female connection from the tank. The male end is 6 AN. So if you have 6 AN hose and hose end laying around you are all set. I think that Summit also sells power steering adapters that are o-ring on one end and pipe thread on the other. Then use a barbed pipe thread adapter to attach a hose. The larger metal tubing to the fuel rail is the supply line.
