Many know to get J30R10 immersible fuel hose for pump replacements. This has been important even before gas has Ethanol now...
Most or all that posted here use 5/16" (~ 8mm) and works for most people....
⚠️ Warning: But steel fuel line to the pump for 87 Duke likely 88 Dukes are
Not 5/16" line
but 3/8" Line.GM to save pennies stop "Necking Down" the Steel Feed Line from the pump.
87-88 V6 likely still requires the steel line at the joint to be 5/16" because of the pulsator only fit that size. But Dukes only use thick rubber and doesn't care about the pump output and line are different sizes.
If you think cost for 5/16" J30R10 is high... 3/8" is often higher cost for 1 foot
and often very hard to get.You may "get away" and force some 5/16" hose on 3/8" line but likely will fail soon down the road. Most hose won't fit bigger line at all. So get 3/8" "rubber" and clamp down to 5/16" on pump output is better.
You can see a V6 shown part of the "neck" section of line in
https://www.fiero.nl/forum/Forum2/HTML/146236.html ... (Edit to highlight that section...)
Was very pissed because of this issue and didn't take pictures of 87 Duke fuel setup at the time.
