theogre,
While you are here... I am making a quick reference card for Fluids and Lubricants. After researching several sources, I was able to boil it down to the following (see attached):
Some sources referred to Corvettes and other cars that have Regular or Limited Slip Differentials and some others features the Fieros clearly do not have - so I did not include those.
As you may know, there is some misconception on what to use in Fiero manual transmissions, some sources (even GM in some cases) state 5W30 Oil, but I believe that
is wrong so I put down Synchromesh Transmission Fluid 5W30 (I think is does not have all the detergents that Engine Oils have).
I think I have it all worked out except for the "Transaxle" which again is shown in red
as 5W30. Correct me in I am wrong, but the Fiero differential is an integral part of the manual transmission, so it uses the same lubricant as the transmission - Synchromesh Transmission Fluid 5W30.
Can you confirm this. What I colored red is what I think does not apply for Fieros.
Are there separate fills for the Transmission and Transaxle? My brother uses to handle all that for me so I am not sure.
Thanks.
Paul Romsky
