  Is there a source to purchase Fiero mating ALDL connectors?
Is there a source to purchase Fiero mating ALDL connectors? by Romsk
Started on: 07-27-2022 07:10 PM
Replies: 7 (205 views)
Last post by: IMSA GT on 07-31-2022 08:00 PM
Romsk
Report this Post07-27-2022 07:10 PM Click Here to See the Profile for RomskClick Here to visit Romsk's HomePageSend a Private Message to RomskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Version 1.6.0 of my free ALDL tool is almost complete. It will be posted soon on paul.romsky.com. I just need to document the special adapter for it that will cost about $20 USD to make.
I am tired of sticking wires into the ALDL socket, it works but that is flimsy.
Does anybody know where the male mate to the Fiero's female ALDL connector can be purchased?
Thanks.
Paul Romsky
[This message has been edited by Romsk (edited 07-27-2022).]
Spoon
Total ratings: 61
Report this Post07-27-2022 07:18 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
For $12 you can buy this on Amazon and cut the end off that you don't need. Splice from there.
Go to amazon and type this: obd1 connector
Spoon
[This message has been edited by Spoon (edited 07-27-2022).]
Romsk
Report this Post07-27-2022 08:32 PM Click Here to See the Profile for RomskClick Here to visit Romsk's HomePageSend a Private Message to RomskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon,
Thanks! I will add that info to my adapter documentation. I found one for $9.
Romsk
Paul Romsky
ArthurPeale
Report this Post07-28-2022 10:57 AM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Romsk:
Spoon,
Romsk
Source for the $9 version?
edit: Amazon has them for even less than that, now that I look. Wow!
[This message has been edited by ArthurPeale (edited 07-28-2022).]
Romsk
Report this Post07-28-2022 05:55 PM Click Here to See the Profile for RomskClick Here to visit Romsk's HomePageSend a Private Message to RomskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 291
Report this Post07-30-2022 05:18 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a one in three chance of getting a connector with pins you need populated with wires. Hit me up if you need a few and I can sell you them. $10 ea plus shipping.
I'll sell you a whole bunch of them with needed pins unpopulated for less.
btw, I do make and sell ALDL to USB cables - http://reddevilriver.com. I designed my own SMD boards, have them made, populate them and then assemble them into the cables.
[This message has been edited by phonedawgz (edited 07-30-2022).]
Romsk
Report this Post07-31-2022 07:14 PM Click Here to See the Profile for RomskClick Here to visit Romsk's HomePageSend a Private Message to RomskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Phonedawgz,
I didn't order it yet. Thanks for the info. If it turns out to be a dud, I will get back to you. The photo shows 12 pins, but true, who knows what they wired to the OBD2 end that I will be cutting off. I hope it has a wire on all 12 pins because I plan to modify my Fiero's ALDL connector: adding the SES signal, the Shift signal, and my own 19200 baud interface to provide: Oil Pressure, Fuel Level, Transmission Gear/Neutral, Brake Pedal Travel, Clutch Pedal Travel, and the dashboard Brake indicator. I will be using an Arduno UNO for that buried under the arm rest.
For this I need ALDL Connector pins:
A Ground
B Diag Mode Select
D SES Signal (not wired on the Fieros)
E 160 Baud Data
F Shift Signal
G Fuel Pump Power
L My Custom Status Extension 19200 Baud interface (usually a no connect pin)
My custom adapter is based on the Adafruit Trinket M0 and will handle all these pins from my Fiero GT ALDL Monitor GUI that I made. It will have a plug in wire for the Fuel Pump Power. One end plugs into the adapter and the other clips on to the battery +. It has a switch so I can stand at the engine and turn the Fuel Pump On/Off to diagnose fuel issues.
Version 1.6.0 will be posted tomorrow, but got to my Fiero page and you can see screen shots on Version 1.5.0 (which never worked too well)
paul.romsky.com
Thanks,
Romsk
Paul Romsky
IMSA GT
Total ratings: 253
Report this Post07-31-2022 08:00 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
phonedawgz, remove the period after your .com in your link.
