  Upgrade to LED 3rd Brake light
Upgrade to LED 3rd Brake light by fierosound
Started on: 08-19-2022 04:14 PM
Replies: 15 (661 views)
Last post by: fierosound on 07-26-2025 08:39 AM
fierosound
Total ratings: 286
Report this Post08-19-2022 04:14 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
For this upgrade, you want the 12V RED 42 LED panel - Dimensions: 127mm x 28mm
(White LEDs will look Pink when shining through a Red lens)
https://www.ebay.ca/itm/253816257643
It's almost a perfect fit, but 2 of the corners need to be filed down slightly. I used an angle grinder with worn out flap wheel.
This is what it looks like with a test fit once you get it right.
Then just solder +Power (Red) and -Ground (Green) wires to the appropriate connections on the panel.
Take the original brake light bulb and snip off the bulb itself. You want the socket.
Solder the +Power and -Ground wires from panel to appropriate leads in the socket - and test.
You can see what orientation I have, but check wiring diagram to make sure.
Last thing I did was add a dab of hot glue in each corner to secure the LED panel.
Installed and looks beautiful. It matches the LED light panels I installed in the GT tail lights. It took less than 1 hour.
[This message has been edited by fierosound (edited 07-26-2025).]
Spadesluck
Report this Post08-19-2022 10:51 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very Nice
ArthurPeale
Report this Post08-21-2022 10:08 PM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it have to be red? The lens is already red.
fierosound
Total ratings: 286
Report this Post08-21-2022 10:20 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you use white LEDs, the end result will look PINK...
ArthurPeale
Report this Post08-22-2022 02:40 AM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Weird. The original bulb doesn't show pink, why would that?
I did my corner lamps with white LEDs, 4000K, the red aren't pink. Is it because of the spectrum of these specific ones?
ArthurPeale
Report this Post08-22-2022 02:48 AM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
ArthurPeale
Member since Jul 2019
Wow, whowoulda thunk? Never given it any thought until now
https://www.autobulbsdirect...b-behind-a-red-lens/
J Gunsett
Report this Post08-22-2022 08:55 AM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Arthur, great video find.
Report this Post08-22-2022 02:34 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
US link https://www.ebay.com/itm/253816257643
While Illegal as other external lights, this is about the only thing to replace w/ LED in Fiero...
Because 889 bulb will cook the fixture and even the trim under it in areas w/ heavy traffic problems. LED could have similar heat problem but will get to it bit later...
I don't like the panel so close to the lens to see dots. Someone make/made an LED that drop in replace for 889 and other in same format but believe that replaces 50+ watt halogen and likely way too bright to replace 889 27w.
Result should be about same brightness as halogen 889 bulb they replace and no-one bothers to test this when finish.
A basic test is find any cheap light meter for cameras etc. then add/use a cut down box to limit extra light pollution and measure output thru the Lens and rear glass before and after to see if their close to same number.
IOW LED may look good in a garage, at night, but often fails in daylight even without direct sun light issues. Or Way too bright and blind drivers behind w/ taillights @ night.
Even ignore that... LED many work for some not other even if all install same way w/ same type for other reason not or barely covered in the cave or anywhere else. Highlights:
Heat they make, Heat when parked outside, and other heat problems.
LED don't like "Dirty" power in most cars either. Nothing to block power noise and surges killing most of the LED "upgrades."
Worse if LED are "over driven" to make more light... Could be the "wrong" choice of resistors etc to limit power. But Remember "12v" in cars is typically 14+v (15-20% more volts) when engine runs and that can over drive the LED too. More so when only have resistors to limit power.
Report this Post08-22-2022 02:41 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Mar 99
This UK "company" looks like many "companies" in the US selling Illegal "upgrades" as in UK MOT will Fail an Inspection installing HID and other crap they sell. Unlike US States that have Poor or No Inspection, Every UK Vehicle must Pass a MOT Inspection and their rules are much stricter then here.
This "video" barely showing some of info covered in my Cave, LED poisoning posted ~ 20 years ago when the lens color doesn't LED light output.
Fiero High Brake Lens like fixtures in the video may match the Red Leds more the other old taillights. "White" LED are use Blue or UV LED to "run" a mix of phosphors to produce whatever "white" output cause problems like any Cool White often output Pink or close to that behind Red LEDs.
It ignores CANBUS LED and Ballast resistors often causes problems adding to heat problems in above post.
fierosound
Total ratings: 286
Report this Post08-22-2022 11:32 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a shorter 24 LED panel (80mm x 28mm) available that could be mounted further back in the housing, and so further away from the red lens.
[This message has been edited by fierosound (edited 08-22-2022).]
css9450
Total ratings: 86
Report this Post08-23-2022 11:04 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
+2
I have the one that Black Top Racing used to sell... It's pink. I like that it's nice and bright but the pinkness of it gives it away as kind of a hack job,
str8maxn
Report this Post08-24-2022 02:31 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
QQ- Can you add a 3rd brake light to an 85 that currently doesn't have one; will it bolt up?
JM
Report this Post08-24-2022 04:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could add one, OE or aftermarket, but car isn't wired etc for them.
Decades ago some sold a kit for 3rd Brake Light to fit most any car like below but now often have to make something to fit.
This came w/ a "module" to wire to the red taillight direct. Also the Lens is Marked as High Mount Brake to meet USDOT rules w/ DOT/SAE U84 CYCLOPS (U is High Brake, 84 year to meet FMVSS, Cyclops for ID who made. See Cave, Lighbulbs @ bottom)
Another version was sold w/o the module for cars w/ amber rear turn lights and was a bit cheaper. (Price is likely 80s to early 90s $ price.)
I found that in a flea market and spent nothing, keep just for showing was a real thing. Was open but only missing vampire taps for wires... (Found those & others parts inside the light fixture later.)
Sold a lot of them for installing in pre-86 cars.
If can't/won't use OE Fiero High Brake unit... Use some other High Brake and wire to brake pedal switch. Often they are LED or use 2 or more small bulbs that won't melt the fixture when stuck in heavy traffic.
E2A--> Cyclops uses 921 Bulb 12v 18w for any might have 1 of this in use. Format sim to 906 in cave lightbulbs.
[This message has been edited by theogre (edited 01-11-2024).]
str8maxn
Report this Post08-25-2022 11:37 AM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for reply....
rbell2915
Report this Post07-25-2025 10:10 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good post. Worked great for me. I put in a flasher with a g-meter from Cravenspeed between the LED panel and the bulb connector, it'll only flash when you're going faster and braking quickly.
fierosound
Total ratings: 286
Report this Post07-26-2025 08:39 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks good! I'm happy you found the information I posted useful.
