  What is this and where should it be?
What is this and where should it be? by John W. Tilford
Started on: 09-26-2022 07:57 PM
Replies: 5 (401 views)
Last post by: John W. Tilford on 09-27-2022 01:23 PM
John W. Tilford
Report this Post09-26-2022 07:57 PM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is this and where should it be? I took the outer skin off the passenger door and this fell out.
I thought it might be the "lock cylinder retainer" but the retainer remains steadfastly retaining the lock cylinder.
I vaguely remember seeing this whatever-it-is over a decade ago when I had a Fiero door apart but don't recall where it's supposed to be or what it's supposed to do.
Thanks for your help.
John T
John W. Tilford
Kitskaboodle
Report this Post09-26-2022 08:34 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think that is the original lock cylinder retainer.
At some point a previous owner changed out the lock cylinder, dropped the original one down inside the door and didn’t try hard enough to fish it out. Maybe his lock replacement came with
the clip? This is why I love my magnetic retriever antenna thingy. Comes in handy for retrieving nuts, bolts, washers, etc from hard to reach places. A tool worth its weight in gold. 😀
Kit
[This message has been edited by Kitskaboodle (edited 09-26-2022).]
Kitskaboodle
Report this Post09-26-2022 08:37 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kitskaboodle
Member since Nov 2004
At some point a previous owner changed out the lock cylinder, dropped the original one down inside the door and didn’t try hard enough to fish it out. This is why I love my magnetic retriever antenna thingy. Comes in handy for retrieving nuts, bolts, washers, etc from hard to reach places. A tool worth its weight in gold. 😀
Kit
John W. Tilford
Report this Post09-27-2022 05:56 AM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll "tack" the outer skin back in place today (including the latch and lock linkages) to make sure everything works before final reassembly of the door.
I'm a little concerned what appears to be the lock retainer in place (see image, although the only part of the retainer visible is the turned-up lip) looks different from the flat mysterious thingie, which has a hole and not a lip.
But, you know, if everything works when the door's done - this all came about due to replacing dew wipes - I'll not worry about it.
Thank you!
John W. Tilford
PhatMax
Report this Post09-27-2022 06:18 AM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like a standard shim for the hinge. Also used to shim fenders or control arms
John W. Tilford
Report this Post09-27-2022 01:23 PM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking shim. I believe the door was part of a Fiero Factory rebuild in 2006 after I totaled the car and bought the carcass back from the insurance company. Who knows the door's history.
In any case, I'll put everything together this afternoon. Maybe keep the shim as a souvenir.
Thank you all for your help.
That's why we have these cars - for the challenge!
John W. Tilford
