Hi All,
I have read a lot about EGR Duty cycles and I understand what a duty cycle is (I am an engineer - but not in automotive), but everywhere I go for EGRs I see good explanations on the Duty Cycle RATIOS but NEVER the FREQUENCY of the cycle (how often it reoccurs).
When I am told that an EGR Duty Cycle is running at 50% I know that it means the Solenoid is activated 50% of the time and deactivated 50% of the time. But nobody ever says anything about how long (in orders of time magnitude) does the Duty Cycle repeat. Is it on the order of minutes, seconds, fractions of seconds?
Also, if the Duty Cycle is at a rapid rate, does that mean that the EGR Valve responds to the average of the On/Off ratio? That is, if at a very fast 50% Duty Cycle, would that mean the valve is 50% steady open (fast Duty Cycle frequency). Or a physically noticeable open 50% of the time and closed 50% of the time (slow Duty Cycle frequency).
Think of a light bulb driven by a 50% duty cycle at a low frequency - you will see the light flicker from full on to full off. But at a 50% duty cycle at a high frequency - you would not see the light flicker but it would appear to be at a steady half brightness. In either case, the light consumed basically is the same amount of light power - it just how much it "flickers" in either case. So, the Solenoid and EGR Diaphragm can work in a similar fashion - so it is a LOW or HIGH frequency duty cycle? - except we are talking vacuum rather than light power.
Look at an Air Conditioner for example, when I say it is duty cycling at 50% it will be on for say 10 minutes, then off for 10 minutes. So, you see, mentioning the Duty Cycle is only half the info - how quickly the duty cycle repeats is an important fact of its overall operation. An air conditioner that was at 50% duty cycle on for 1 second and off 1 second would not be energy efficient and destroy the compressor quickly.
So I gave two examples on knowing the frequency of the duty cycle as an important factor in knowing exactly how the EGR works.
Has anyone actually monitored the EGR Solenoid signal to see at what rate it goes on and off as well as its duty cycle ratio changes?
Thanks
Paul Romsky
[This message has been edited by Romsk (edited 10-02-2022).]
