  re: Replacing sunroof weatherstrip
re: Replacing sunroof weatherstrip by TheDigitalAlchemist
Started on: 10-06-2022 11:05 AM
Replies: 14 (354 views)
Last post by: TheDigitalAlchemist on 10-09-2022 11:19 PM
TheDigitalAlchemist
Total ratings: 94
Report this Post10-06-2022 11:05 AM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Might need to replace the weatherstrip on an 86. Just a few questions...
1.does it just 'pull out', or is it usually glued in place?
2. what do you recommend I use to remove anything there? (3M Adhesive Remover?)
3. When installing the new one, should I apply the 3M Super Weatherstrip Adhesive on both the (cleaned) frame and weatherstrip?
(smear a thin coating on each, allow to get "tacky", then apply another thin smear on the weatherstrip and attach to frame?
Thanks in advance!
Report this Post10-06-2022 09:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the old weatherstrip actually damaged?
The reason I ask is that some people mistakenly believe the weatherstrip is to blame if a bit of water leaks into the cabin when it rains. It's often just that the four drain holes are plugged. When they're clear, a Fiero can be driven in the rain with the sunroof open... and water does not enter the cabin. It's something I do all the time here on the (usually) rainy west coast of BC.
Report this Post10-07-2022 10:27 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll email you the Drain Hole Fix. The document also includes where adhesive is to be applied when removing and replacing the seal. I tried to attach it here, but it's a document, not an image.
TheDigitalAlchemist
Total ratings: 94
Report this Post10-07-2022 07:27 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, we haven’t had a chance to examine it much yet…
Report this Post10-09-2022 07:12 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The email address in your profile isn't valid. The email bounced back.
Steel
Report this Post10-09-2022 07:58 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
+1
Was going to say the same but Patrick addressed it first.
TheDigitalAlchemist
Total ratings: 94
Report this Post10-09-2022 09:49 AM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry about that - I updated my email.
TheDigitalAlchemist
Total ratings: 94
Report this Post10-09-2022 01:14 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
TheDigitalAlchemist
Member since Jan 2012
Didn't get a chance to really examine it- I'm not sure that the weatherstrip is sealing well against the glass. I'm aware that there are drain holes but haven't looked at it yet.
Heard that applying Castor oil can help revitalize the seal a bit. is that true?
Report this Post10-09-2022 02:53 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've used castor oil and it does help to swell the seal. It takes time, not instantaneous. Just got home and sending the file.
Report this Post10-09-2022 04:36 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sure, it's preferential to have the weatherstrip seal against the glass, perhaps more for preventing potential wind noise than water infiltration... but I just want to reemphasize, the rubber weatherstrip seal does not need to seal against the glass to keep water out as long as the four drain holes are free of debris.
I have used castor oil on my sunroof rubber weatherstrip seals... maybe twice in 25 years. I just don't see a real need for it.
TheDigitalAlchemist
Total ratings: 94
Report this Post10-09-2022 04:44 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, I need to make 4 holes in the inner corners of this plastic part? (Where the white dot is?) That area is where the water was.
3 of the four corners have rust, should we replace the tracks?
[This message has been edited by TheDigitalAlchemist (edited 10-09-2022).]
Report this Post10-09-2022 04:52 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
NO !
Give me a couple minutes to find the proper instructions...
Okay, I found a picture that I "tweaked" and posted years ago which show where the holes are supposed to be located. The earlier years (84-86?) didn't originally have the holes from the factory, but smart owners have added them.
Go Here for instructions if you need to drill the holes... but it's possible you'll find they're already there. In case that link dies, here's a screen grab of the most pertinent info.
[This message has been edited by Patrick (edited 10-09-2022).]
TheDigitalAlchemist
Total ratings: 94
Report this Post10-09-2022 05:09 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
NO !
Ok, Thanks...
Report this Post10-09-2022 05:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking more closely at your photos, I can see you've already got at least one hole drilled in the panel, and all four are probably there. Perhaps you'll find one or two that are plugged. Clean all that crap out from beneath the weatherstrip! (A shopvac with a crevice tool should do the job fine while you're holding the weatherstrip back out of the way.)
TheDigitalAlchemist
Total ratings: 94
Report this Post10-09-2022 11:19 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
cool, will do!
