  The hose
The hose by Esha707
Started on: 10-11-2022 02:19 AM
Replies: 4 (176 views)
Last post by: Raydar on 10-11-2022 02:00 PM
Esha707
Report this Post10-11-2022 02:19 AM Click Here to See the Profile for Esha707Send a Private Message to Esha707Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone I am new to having a fiero. It's my first project car and I am stumped. I have a hose on my 86 fiero gt that I don't know where it goes and I was hoping someone would know or have an idea of where it does go. It's a hose leading from under in the intake manifold. I noticed it when I was taking off the thermostat housing that it was just dangling there. Please let me know and thank you in advance
Xenoblast
Report this Post10-11-2022 03:16 AM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like the vacuum line for the map sensor. The upper one plugs into the intake plenum near where the map sensor is mounted.
fierosound
Total ratings: 286
Report this Post10-11-2022 07:41 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree.
Dukesterpro
Report this Post10-11-2022 10:37 AM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heed my warning,
Replace that T-Joint, yours look old and stretched out. Mine was creating a leak that was preventing my engine from staying running. You can get the right parts at autozone or the like, just replace all the fittings while you are there.
Total ratings: 460
Report this Post10-11-2022 02:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Dukesterpro:
Heed my warning,
Replace that T-Joint.
Second this.
Most of the vacuum-related issues that I've encountered with Fieros (and lots of other cars) have been caused by degraded rubber - fittings and/or hoses.
You should be able to find replacements at Advance Auto.
(I have gone as far as to replace all the plastic hard lines with rubber tubing, using plastic "T"s, etc. This was with a different intake manifold, however.)
