Stant Co. is still around but they Sold aftermarket division to MotoRad that quickly killed the brand.
MotoRad makes many "Store Brand" caps for years so many use their rad caps but never knew it.
But their T-stat covers had problems because of rubber seal is too wide and won't fit in some cars.
87 & up "dukes" have an Updated T-stat Tube and I've tried MotoRad in the past and refuse to install.
Current MotoRad T32 on their site seems to be Stant cap but buying one may get the old one that's had the problem just said.
IOW look @
motorad.com/motorad-catalog...ocator/part/?pid=T32 old MotoRad rubber filled the cap and no margin like above pic.
Note: While MotoRad shows above pic & listed as Stant part in other sites. Don't believe that pic = to the part you get. Most Vendors do not have "NOS" Stant parts & even if label as Stant, is a MotoRad part & may not fit you car. I'm not sure even the pic below is actual current MotoRad part.
I knew some months back but I'm posting this because just a T-stat cap leaking and may need to use my spare Stant cap.
I had it off replacing the Intake Manifold Gasket and dripped a few days after reusing the cap. I cleaned more carefully and coat w/ Brake Grease and so far seem that solve the leak.
⚠️ Warning: While Stant covers are made to swivel so easy to install and remove... The rivet in the T-stat cover center can rust and stop this.
Coat the rivet w/ Silicone Oil to keep out weather etc attacking the top when on the car.
Similar reason to coat the tube lip etc w/ brake grease to prevent rust that often locks the cap to the tube.
Silicone and Permatex brake grease won't wreck the rubber seal. Do Not use other oil or grease.
Stant SuperStat® Thermostat is likely gone... Quick search 195° 45819 is not found at most places now. This T-stat type slows or stops temp gauge bouncing that many see in Fiero in cool/cold weather because of 14+ quarts of coolant to heat.
I doubt MotoRad is making this under new number or maybe only making as base model...
]⚠️ Watch buying New Radiator caps... MotoRad and thus many store brands Does Not list a non-vented cap for Fiero. vent/non-vent caps had a letter at end of some PN. Even w/ that data seems have renumber(ing) the radiator caps.
So for Fiero... A few cross ref 1008-16 as Stant 10231 or Motorad T16V vented caps.
By cross ref Stant 10230 not Year etc of car here. For MotoRad and many "store brands" T16.
Note that both T16 are "locking caps" that you pull up the lever... I never like this type even from Stant because locking pin often leaks air so recover/overflow tank doesn't work right.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 11-07-2023).]
