Some gaskets are about same across brand and doesn't matter much.
Felpro w/ Print-o-seal, permadry, and related are made to fix some issues/problems. If Felpro has a gasket w/ those term(s) I get them.
Many gaskets get installed Dry that means w/o any sealer.
Oil Pan sets often need RTV but Only @ joints where sections meet or overlap. Read Directions that come w/ many sets or FSM etc.
RTV only can work but have rules to use. Highlights:
1. Is Clean Everything that the sealer will be applied. Brake clean or alcohol as final step.
2. Do Not get sloppy and use too much. Any that squeeze out you see has done same where you Can't see or clean then boogers can cause problems.
3. If has big gaps to seal then expect will need days or longer to fully cure. "Dry to Touch" is not Cured RTV no matter what label say about cure time.
GM and others use RTV in many parts but often these parts are made for this setup.
Example: SOME Dukes Valve Covers are made for RTV and mod'ed the holes and flange to set right gap for RTV sealer. Early ones use a gasket.
But often they leak from age or repairing problems and Felpro Silicone Set w/ extra hardware and way more expensive is about the only way to install Duke Valve Covers and never leak again.
