  Temp Gauge Sending Unit Issues
Temp Gauge Sending Unit Issues by stark86
Started on: 03-10-2023 06:44 PM
Replies: 20 (480 views)
Last post by: Rhodesia1977 on 03-26-2023 02:39 PM
stark86
Report this Post03-10-2023 06:44 PM Click Here to See the Profile for stark86Send a Private Message to stark86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello Fiero Forum,
A couple weeks ago I picked up an '86 GT from a neighbor that's been sitting for years; Nevertheless, I got it running and it seems to be in good condition overall (apart from the moldy interior and seized up shifter assembly). Now one issue I've been fighting is the Temp Gauge--I realized that after idling for considerable amount of time, the gauge would barely move, although the radiator cap is warm to the touch (I already replaced the thermostat).
Not trusting the gauge, I tested its accuracy by connecting resistors to the wire, and all seemed to be good. So, I ordered a Temp Gauge Sending Unit from the Fiero Store and installed it--But now, instead of moving little, the temp gauge wont move at all. I took a multimeter and attached the negative probe to ground, and the positive probe to either pin on the Sending Unit, which displayed an Open Loop on by meter. Believing that the Teflon tape on the threads could be blocking the sensor from getting a good ground, I used tiny jumper cables to connect the gauge to the negative terminal--Still nothing.
I already (stupidly) threw away the old Sending Unit, so I can't cross-examine my testing with the old part. Am I doing something wrong? Could my sending unit be faulty? Please bare with me: I'm fairly new to wrenching on cars and VERY new to dealing with electric.
Thanks
Report this Post03-10-2023 07:14 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the forum... and to Fieros!
Electronics aren't my strong suit... but this chart may help you.
Spoon
Total ratings: 61
Report this Post03-10-2023 07:18 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Easy test,
https://www.youtube.com/watch?v=pWBsq0J9McI
Spoon
armos
Report this Post03-10-2023 07:38 PM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is from the 86 service manual:
it agrees with you that one terminal of the gauge sender should be in contact with ground. However, that ground might be coming from the wire that plugs into it. Do you have ground contact on one of those 2 wires?
[EDIT]:what you said is probably correct - there's probably no ground at either wire or terminal, and it strictly grounds through the threads.[/EDIT]
I tried to check my car, but I can't figure out how to get the connector off without breaking it.
They also say there should be a resistance of 1365ohms across the terminals of the sender at 100F, and 55ohms at 260F.
So if you plug 68ohms into the connector the gauge should point almost at 260F.
There's a more complete chart of resistance values for the other temperature sensors (which connect to the ECM), but at least some info says that the gauge sender uses a different scale than those others.
[This message has been edited by armos (edited 03-10-2023).]
stark86
Report this Post03-10-2023 08:06 PM Click Here to See the Profile for stark86Send a Private Message to stark86Edit/Delete MessageReply w/QuoteDirect Link to This Post
If I'm testing this right, I don't think I have ground contact on either wire. But shouldn't the ground contact come from the threads on the sensor contacting the cylinder head?
Report this Post03-10-2023 08:14 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by stark86:
...shouldn't the ground contact come from the threads on the sensor contacting the cylinder head?
If it had a single wire like the fan switch... yes, it would then definitely need to ground out through the base... but I admit I'm not 100% sure about this temp sender.
[EDIT] According to The Ogre's Cave, that temp sender does need to ground through its base.
Resistance to ground for gauge.
Don't use Teflon thread sealing tape on grounded shell NPT sensors. It will likely interfere with getting a good electrical connection through the threads.
[This message has been edited by Patrick (edited 03-10-2023).]
stark86
Report this Post03-10-2023 08:47 PM Click Here to See the Profile for stark86Send a Private Message to stark86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I see what appears to be ground symbols on the box containing the labels "Sender Resistance" & "Switch," so if I'm reading the diagram right, the ground connection would come from a source other than the two wires, which is what I'm assuming to be the base of the sending unit. I'm gonna be honest, this is my first time trying to decipher a wiring diagram, so I may be wrong.
EDIT: Just saw your edit -- That makes sense... I'm gonna take the teflon tape off (That was pre-applied) tomorrow and see if that does anything. Fingers crossed there's no leaks
[This message has been edited by stark86 (edited 03-10-2023).]
Report this Post03-10-2023 08:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...if I'm reading the diagram right, the ground connection would come from a source other than the two wires, which is what I'm assuming to be the base of the sending unit.
Yes, correct. That's what I added above.
Report this Post03-10-2023 09:33 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes... Fiero and Thousands of others, Any Sender for Dash Gauges ground thru the base.
Teflon tape can cause problems with them.
ECM Temp sensors and many others have 5V and/or Ground wires + "Data" wire.
While many love Teflon Tape... Is a pain to clean if have to take apart again for any reason. (Hard to apply w/ one hand too.)
RectorSeal and other "pipe dope" that dries have same or worse problem. You often need Dremel w/ Wire brush tip etc to clean these.
Is why I use Non drying Teflon pipe dope on most things. Example: https://www.lowes.com/pd/Oa...hite-Sealant/4750813
Plus this stuff will last a long time after the can is open. I've been using same can for 15+ years.
Others can/will dry in the container after first use.
sanderson231
Report this Post03-11-2023 11:34 AM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure you bought the right sensor? There are two coolant temperature sensors. One is a combination sender and switch. The sender is for the instrument panel gauge. The sender is variable resistance and goes to ground via the threads. The switch is for the coolant temperature warning light. The switch also goes to ground via the threads.
The other sensor is a variable resistance sending unit connected to the ECM. The ground is in the ECM.
So check the resistance on the sensor you bought and see if there is continuity to the threads on the "A" wire (should be about 1400 ohms at room temperature) . If not, I think you have the wrong sending unit.
formerly known as sanderson
1984 Quad 4
1886 SE 2.8L
1988 4.9L Cadillac
1988 3800 Supercharged
Report this Post03-11-2023 06:32 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Again, ECM sensors has no connect w/ base except "1 wire" O2.
New ECM sensor you buy uses competently and can't use other plugs. Can't even use the old plug and buy a new plug.
stark86
Report this Post03-12-2023 03:09 PM Click Here to See the Profile for stark86Send a Private Message to stark86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Took the Teflon tape off, didn't work.
The part I ordered from TFS is the 84-88 Temp Gauge Sending Unit, Part # 51404.
This is how I'm measuring the resistance. I tried with the positive probe on both pins to no avail.
Did I just get unlucky with a DOA Part or am I being stupid and doing something wrong?
[This message has been edited by stark86 (edited 03-12-2023).]
cyrus88
Report this Post03-12-2023 04:04 PM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is the temp of the room in which you are bench testing this new sensor?
If it is less than 90F you have to put your DMM setting greater than the 2KOhm range you have showing in the pic above (see the temperature chart in the first reply to your question).
Report this Post03-12-2023 04:40 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like said just above... 1 pin needs next range to read Ω.
Other pin will Never get Ω because the switch is open. Only "test" here is Hot Oil heated to > 260°F. Not a good plan for many people.
Using a torch etc on the tip can heat too high or too fast and break the part.
E2A--->Think above chart is for ECM ECT sensor... While both use NTC, Gauge has different values/curve for it.
[This message has been edited by theogre (edited 03-12-2023).]
stark86
Report this Post03-12-2023 04:40 PM Click Here to See the Profile for stark86Send a Private Message to stark86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still getting nothing in the 20k Ohm Range. 70 degrees F in here.
sanderson231
Report this Post03-12-2023 04:53 PM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check the resistance between the two pins of the sender. If there is continuity you have the wrong sensor.
1984 Quad 4
1886 SE 2.8L
1988 4.9L Cadillac
stark86
Report this Post03-12-2023 05:03 PM Click Here to See the Profile for stark86Send a Private Message to stark86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm getting nothing between the two pins.
sanderson231
Report this Post03-12-2023 10:09 PM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
No resistance or an open circuit?
[This message has been edited by sanderson231 (edited 03-12-2023).]
stark86
Report this Post03-12-2023 10:14 PM Click Here to See the Profile for stark86Send a Private Message to stark86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Open circuit on both pins.
stark86
Report this Post03-19-2023 02:00 PM Click Here to See the Profile for stark86Send a Private Message to stark86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update: It just ended up being a faulty sensor... lucky me I guess. I followed Ogre's advice and put PTFE pipe joint compound on and it works great now. Thank you to everyone that replied
Rhodesia1977
Report this Post03-26-2023 02:39 PM Click Here to See the Profile for Rhodesia1977Send a Private Message to Rhodesia1977Edit/Delete MessageReply w/QuoteDirect Link to This Post
My 86 did the same thing. The plastic thing that holds the snap on to connect to sensor was missing. It was just 2 separate green wires both unmarked, naturally! I installed new sensor and then mistakingly switched the wires that go to the sensor and ever since then, it has worked fine. It is off by 15 degrees however. Also, get yourself a Lazer thermometer and take readings at the base of coolant gauge temp sender sensor. It should give you a good idea of the temp.
