  Fiero 5-speed Clutch Lever / Arm
Fiero 5-speed Clutch Lever / Arm by Fluidic15
Started on: 03-27-2023 02:40 PM
Replies: 8 (720 views)
Last post by: fierosound on 06-23-2023 12:18 PM
Fluidic15
Report this Post03-27-2023 02:40 PM Click Here to See the Profile for Fluidic15Send a Private Message to Fluidic15Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello,
Recently I recently ran into a problem with my 1987 Pontiac Fiero SE. It has a 5 speed isuzu transmission, and the plastic insert on the clutch arm broke. There is no good way for me to recreate this plastic piece and maintain the strength that it once had. The link lower in the post is for the diagram that I found to be most accurate to the assembly, and the part that I am referring to is first on the list (001 LEVER, CLU FORK (1986-87 MG2) (CA, US)) I have searched through other threads and have had no luck. So far I have found that this part was once reproduced although I am not sure if it is available for purchase any longer. If anyone has a good idea of where I may be able to find a working clutch arm, or the cast steel version any help would be incredibly appreciated.
https://nemigaparts.com/cat...c/22p-p/00/2p00-016/
Thank you for taking the time to read,
Arie
[This message has been edited by Fluidic15 (edited 03-27-2023).]
Total ratings: 200
Report this Post03-27-2023 07:41 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Fluidic15:
Hello,
Arie
Hi! Welcome to Pennock's! I see this is your first post. I too have a 1987 Fiero SE. You mention an Isuzu, so I assume it's a 4 cyl? I'm just curious, do you have any pictures? The 87 SEs with 4 cyls are super rare... doesn't really make them any more valuable, but they were rare never the less. It was a model that basically came with all the V6 stuff... trumpeted exhaust pipes, aero package, the extra gauge pod that sits on top of the HVAC vents in the center console, etc.
Just wanted to be clear this is what you had. If you have a V6, then your transmission would be the 5-Speed Getrag.
sleek fiero
Report this Post03-27-2023 07:59 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I think i would take the arm and slave cyl to a local machine shop and have them turn some industrial bushing plastic on the lathe . if too expensive maybe someone on the forum might have one that is still useable. But remember a used one will be 36 years old and may fail like the one you have. sleek
Fluidic15
Report this Post03-27-2023 08:32 PM Click Here to See the Profile for Fluidic15Send a Private Message to Fluidic15Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it is a 4 cylinder. I have a had a hard time finding any information on my exact Fiero so the fact that they are uncommon would make a lot of sense. I attached some pictures of the plastic piece that broke, as well as where it was located on the arm. I also attached a picture of the entire engine bay for reference.
Fluidic15
Report this Post03-27-2023 08:36 PM Click Here to See the Profile for Fluidic15Send a Private Message to Fluidic15Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fluidic15
Member since Mar 2023
I will look into getting the piece machined. In my research I found that at one point a completely steel part was produced instead of steel and plastic. Because this part is no longer made ideally I would like to find someone who bought the steel part while they were still being produced and are willing to sell. You do bring up a good point about used parts being just as reliable as the one that broke, but in the meantime my fiero is not driveable so anything will do.
Thanks for your time,
Arie
Report this Post03-27-2023 09:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Considering all the various transmissions (Isuzu, Muncie, Getrag, 4-spd, 5-spd) that have come in Fieros from the factory, I'd be pretty surprised if there wasn't a lever from another application that would work.
I have an Isuzu 5-spd swapped into my '84 (with a duke), and it seems from what I remember that the lever is a solid metal unit. I'd have to take a look to verify that. [EDIT] Well, so much for my memory. (I was probably thinking of the Getrag in my '88.) I had a look at my '84 and it's the same clutch lever as pictured above.
[This message has been edited by Patrick (edited 03-28-2023).]
sleek fiero
Report this Post03-27-2023 11:25 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
good pics. Yes my 85 with 4 speed has very similar arm if not exactly same. If you cannot find a used fiero one you might get one from a caviler or citation or sunbird. these transmissions were used in multiple GM econoboxes. the piece that is broken loose is for the slave pushrod ball end to ride in and allow the arm to pivot to keep alignment.
Probably one could be made out of metal without too much effort. It looks to me that the lock tabs have broken off the pushrod side of it but the rest is still in tact to use as a pattern.
[This message has been edited by sleek fiero (edited 03-27-2023).]
stevep914
Report this Post03-28-2023 02:33 PM Click Here to See the Profile for stevep914Send a Private Message to stevep914Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a customized 86 Fiero/Ferrari F40 that came with a V6 and a 5 speed Isuzu transmission. And if I remember correctly, it has a plastic insert in the clutch arm for the pushrod from the slave. I guess I should take another look at that, and see if it is showing any signs of deterioration. I know when I redid the clutch disc and resurfaced the flywheel, I had to work with what was in the car, because other parts did not mate up.
fierosound
Total ratings: 286
Report this Post06-23-2023 12:18 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney Dickman to the rescue with new products.
http://rodneydickman.com/
