Note: My post above is for OE Fiero and other "Dumb" units that lets air/fumes flow all the time for port for the tank.
Small ports don't flow to test w/o following "rules."
1 port never flows as it opens a valve for the other small port under vacuum.
Other small port has that valve that's closed w/ engine stopped.
Also... Another version of the Can has different port(s) because the small ports on Fiero can moves to "remote control" in another part. Either a "Dumb" or ECM/PCM remote controlled. Dumb units have same "dome" snap to the bottom like Fiero units. You need the dumb control and can to hopefully work in normal Fiero.
| quote | Originally posted by Spoon: Why buy or bother with used 20+ year fuel Vapor canister when new ones are still available. |
Was available and fairly cheap but Not Fiero and many other old cars now.
Most stopped carrying that part years ago because whoever made it stopped and just run out of inventory. Might find NOS EVAP "cans" on E-bay or RA at different times.
⚠️ Warning: Many say the "can" but only have the Filter for the bottom and cost a lot at "GM Parts" online like ~ $20 to $30 just for the bottom filter.
Might find Fram bottom filter but I think Fram no longer make them.
