This weekend I'm going to try to work on a few wiring projects on my 88 coupe, first of which is my tach. It hasn't worked since I got the car. My idea now is to cut the tach signal wire coming from the ignition control module and run a wire directly to the tach. At this point I want to take the tach out of the car and try to get it working manually on my workbench.
I can hook the tach signal wire from the 3800SC's icm directly to that bolt that says coil? Then just 12v hot and ground and it should work? If that doesn't work, does that mean my icm is bad?
From what I know, there's another wire to runs to the pcm that gives it a tach signal, and this other wire is an old-school tach signal that is supposed to go directly to a tachometer. In the Grand Prix its not actually used but it still has signal.
I was also thinking of running a wire up to the tach wire that runs through the center console, but on this site
http://www.nathanbittinger....roaddiction/c203c500 I don't see a tach wire there at the C203 connector? How is it routed from the C500 into the interior and to the dash???
