  Valve Cover Bolt
Valve Cover Bolt by Brent7088
Started on: 06-03-2023 02:53 PM
Replies: 5 (372 views)
Last post by: Brent7088 on 06-03-2023 04:52 PM
Brent7088
Report this Post06-03-2023 02:53 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there any possible way to get this rear valve cover bolt off without having to remove the bracket that's blocking it?
Report this Post06-03-2023 03:53 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the intention to then remove the valve cover? If so, the bracket may be in the way to lift the valve cover out of there anyway.
Why the reluctance to just simply remove the bracket first? It's not a difficult job.
Report this Post06-03-2023 03:58 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If 1/4" drive socket and extension won't clear very few other ways will.
HF and others make "tip able" and flex extensions so can "bend" the socket some may help.
Not like "universal" part that take more space to attach.
Even If bolt is out... cover may not clear the rockers w/o bracket removed.
Brent7088
Report this Post06-03-2023 04:00 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I'm going to replace the gaskets. I was just not sure what that bracket was holding up from underneath, or what its purpose was.
Report this Post06-03-2023 04:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's part of the assembly that the dogbone is attached to. Nothing needs to be accessed from "underneath".
In this photo from my valve cover removal thread, you'll notice that bracket has been removed... in order for the valve cover to be lifted out of there.
[This message has been edited by Patrick (edited 06-03-2023).]
Brent7088
Report this Post06-03-2023 04:52 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
I understand now. I'll just loosen a couple of the nuts and swing it out of the way.
Thanks Patrick and Ogre.
