  eProm causing erroneous codes?
eProm causing erroneous codes? by c4hammer
Started on: 06-08-2023 07:56 PM
Replies: 9 (601 views)
Last post by: c4hammer on 06-12-2023 12:33 AM
c4hammer
Report this Post06-08-2023 07:56 PM Click Here to See the Profile for c4hammerSend a Private Message to c4hammerEdit/Delete MessageReply w/QuoteDirect Link to This Post
A brief background:
I just purchased an '88 GT, with the 2.8L and 5 speed manual this past weekend. No moonroof or t-tops. The engine idles high, between 1.5k and 2k, so I'm assuming I need to deal with EGR valve/tube/solenoid.
In addition, when driving it home the first time, I turned on the A/C, and got a little smoke through the vents and heavy exhaust fumes/smell. Running A/C on Max helps, but I've been just leaving the windows down even though it's HOT right now in Texas.
So the real point of this post -- because I had a couple things going on, I picked up a scanner that could handle OBD1. I've got a whole slew of issues noted: EGR, MAP, voltage high for too long, EPROM incorrect, Oxygen senor, and a few more that are error derivations of the EPROM/ECM. My question is, if someone has already installed an aftermarket PROM, would it cause incorrect codes? Or do I really have that many issues to tackle?
Mickey_Moose
Total ratings: 145
Report this Post06-08-2023 09:01 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well for one thing, the EPROM code should be on the label on both the ECM case and on the EPROM itself. Generally it is a 4 letter code, AKYN for example, but there are also some 3 letter codes.
Report this Post06-08-2023 10:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Read this thread before you burn up your Fiero!
Heat/AC box cleaning, again...
[This message has been edited by Patrick (edited 06-08-2023).]
Report this Post06-09-2023 11:04 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Erroneous codes could be the result of a bad ECM. They do go bad.
Report this Post06-09-2023 01:35 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
could be that... smoke and smell help saying that.
Also if heater core leaks coolant... could seem to smoke but different smell. Plus often leak coolant on P-side floor when core is bad.
Report this Post06-09-2023 02:34 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Mar 99
ECM w/ Bogus "Codes" is often bad "Grounds." Some labeled Grounds even by GM are not real ground but return wires for some functions like "1 wire" O2 sensors.
Find and fix all grounds in engine bay and use silicone or permatex green brake grease to "seal" them and won't "eat" plastic and rubber.
armos
Report this Post06-09-2023 08:55 PM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
Definitely check for buildup of old leaves in the ducting as mentioned above. My car was loaded with them and they can start to burn as described in that thread.
If you have any of the "5x" codes then I'd ignore the other codes until those are fixed, because they are messing with the sanity of the ECM.
If you have code 53 (system over voltage) then get a multimeter and check the voltage of the battery circuit while the car is running. This code is set if the ECM detects over 17.1V, which is excessive. I don't know how much input voltage the ECM components are specced to tolerate before they'd be damaged.
If your meter agrees that the car is running on over 17V, the other error codes might not be reliable. Fix the voltage first. Replace the whole alternator or test/troubleshoot it and at least replace the voltage regulator in it.
If you have code 51, this means the EPROM is failing the checksum, which means it is corrupt.
If so then you need to get into the ECM. Remove the shift knob, screws from underneath the ashtrays, get the shift console out. Then pull the top of the large center armrest piece towards the front of the car and it should tilt forward and come out, unless there's screws I've forgotten. ECM is behind where the map storage door thing is.
Open the rectangular door on the ECM. The EPROM is the wider (24 pin I think) chip, in a black plastic carrier on the driver's side of the ECM. Note the orientation of the EPROM - you have to plug it back in the same way. There's always a notch or a dimple on one end of the chip itself (not sure if it's visible inside the plastic carrier). Pull the plastic carrier to remove the chip and carrier as one piece. Look at what markings are on it. There should be a code on it as mentioned above.
If my info is correct than the factory chip for an 88 Federal 5spd V6 should be AKYN3442, and factory chip for California cars should be AKYP3447.
Assuming it's the correct chip then you don't need to remove it from the carrier. Doing so may lead to damaged pins, it's not easy to get out. I swapped to an older chip carrier from a 1984 ECM on my car because it was much easier to deal with for me.
Plug it back in, making sure the orientation is correct. If you plug it in backwards it will fry the chip. Try again, hopefully reseating it will have fixed the code 51. I've had this happen a couple times on my car and had to reseat the chip, but that might be because I've messed with it a lot.
When you first turn on the key, the "check engine" light should turn on, then blink off for an instant, then turn back on and stay solid. That blink tells you the ECM is functioning (but not necessarily happy).
[This message has been edited by armos (edited 06-09-2023).]
c4hammer
Report this Post06-10-2023 11:46 PM Click Here to See the Profile for c4hammerSend a Private Message to c4hammerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks everyone -- I did indeed have the buildup in the blower/heater element box. I've clean as much as I could without taking it apart, and I'll be doing that long before I need to use that heater element.
That doesn't seem to change the exhaust smell in the cabin, so I still need to track down potential a/c system leaks or exhaust leaks.
Thank you so much for the 5x codes info, armos -- that's where I'm starting on the code troubleshooting.
Report this Post06-11-2023 12:30 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Keep in mind we're not talking about a "heater element" that gets hot. It's the resistors for the fan motor that get hot. If you run the A/C on anything other than the fastest speed, the resistors are being used by the fan motor... and getting hot.
c4hammer
Report this Post06-12-2023 12:33 AM Click Here to See the Profile for c4hammerSend a Private Message to c4hammerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gotcha Patrick, I was looking at the resistor coils and thinking heater elements. I'll be sure to take care of that buildup.
