  Another clutch woe
Another clutch woe by PhatMax
Started on: 06-19-2023 08:49 AM
Replies: 5 (414 views)
Last post by: shemdogg on 06-19-2023 09:41 PM
PhatMax
Report this Post06-19-2023 08:49 AM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here’s what I have and a thought on what’s going on.
I have the steel clutch pedal, new clutch, SS lines, Rodney’s master and slave. Clutch fork was inspected when motor and trans were out of car. So, bled the master, banjo up, clear fluid at slave. Slave only moves about 3/4”. Grabbed slave rod, pulled back while buddy opened bleeder, barely any fluid came out. Did this 4 times. After a while of pondering…..I had my buddy slowly push the pedal down while I watched the slave rod….pedal moved a bit before rod did….so I thought “let’s move the banjo so the rod moves as soon as the pedal is pressed. At that point I could get it into gear while running but it didn’t feel,right. Felt like It was bottoming out the MC…..not cool. So I’m stuck on what to do next.
This maybe the answer…haven’t tried it yet. Since the system is a very basic hydraulic set up when you push the rod back into the slave it should just push the fluid back to the MC….correct ? So maybe there needs to be a bit of pressure on the pedal to put the master into the “fluid pushing operation” then try pushing the rod into the slave and crack open the bleeder to get air out….does this make sense?
shemdogg
Report this Post06-19-2023 09:13 AM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you push the rod back into the slave while the bleeders there, you will be pushing the air in the slave back into the line. Jack up the front so the masters higher than the slave, bleed the system, remove the bleeder, remove the slave, w one hand push the slave against the trans or bracket to push the slave rod all the way in, while its in, install the bleeder tight w other hand. reinstall slave, should be good to go then. If not extend your slave pushrod a bit. Make marks on the trans housing w a sharpie w the arm at rest and fully extended to measure how much throw you have. I wound up putting an izuzu slave on my getrag to get the extra throw.
shem
PhatMax
Report this Post06-19-2023 09:37 AM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Curious as to why the front of the car needs to be higher.
I will give that a shot today and report back
Larryinkc
Report this Post06-19-2023 11:02 AM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
From V8 Archie
http://www.v8archie.com/v8Archie/ToC6.htm
Clutch bleeding prodeedure
You can do it your way, But this method always works for me.
After checking to be sure there are no leaks in the Clutch Hydraulic system.
Complete ALL of the following steps before test driving the car:
1) Install a helper in the drivers seat to push in and let out the clutch pedal on command.
2) Remove the cover from the Master Cylinder reservoir.
3) Top off fluid in the reservoir.
4) During the course of this procedure DO NOT allow the "helper" to "pump" the pedal. The "helper" is to depress and release the pedal on command only, DO NOT PUMP THE PEDAL. (See theory below)
5) You will be opening and closing the bleed screw on the slave cylinder as instructed below. CAUTION: During this procedure protect your eyes from squirting brake fluid.
6) (Helper) Press clutch pedal in fully and hold.
7) (You) Open the bleed screw to allow fluid to escape.
8) (You) Close bleed screw.
9) (Helper) Release pedal completely
10) (You) Top off fluid in reservoir.
11) Repeat steps #6 thru #10 no less than 5 times before going to #12 below. NO PUMPING!
12) You have now bled the Master Cylinder and the hydraulic line. YOU ARE NOT DONE YET!!!!! We must now bleed the Slave cylinder. (This is what the manual doesn’t tell you)
13) With no further action to be done with the clutch pedal, you can no remove the "helper" from the drivers seat and have him (her/it) help you do the following.
14) After topping off the Master Cylinder, completely remove the bleed screw from the slave cylinder.
15) Have the "helper" stand at the ready with the bleed screw and the appropriate wrench for installing the bleed screw.
16) PROTECT YOUR EYES!
17) With the bleed screw removed. With both hands grab the push rod coming out of the slave cylinder and push it into the slave cylinder as far as it will go AND HOLD it in.
18) Your "helper" will now install and tighten the bleed screw while you hold the plunger in.
19) When bleed screw is tight release the rod and as it comes out guide it into the proper position on the clutch arm.
20) Top off the Reservoir and the job is complete.
Theory:
Why do I insist that you REMOVE the bleed screw when pushing the plunger in on the slave cylinder? This is simple hydraulics. Fluid or air will always go the direction of least resistance. When you are pushing the rod into the slave cylinder you will find that it is impossible to push it in at a slowly and steadily pace. If you push it in too fast with the bleed screw still in and just unscrewed a few turns some of the brake fluid and/or air in the slave cylinder will go back up the hydraulic line that you just bled, thus necessating your starting over.
When bleeding your clutch....The biggest mistake or miss-conception a person can make is to pump the pedal.
The clutch Hyd. system, unlike the brake Hyd. system SHOULD NOT BE PUMPED. The only thing that happens when you "pump" the clutch is that you make any large air bubbles in the hydraulic system into a bunch of small air bubbles. BTW these small air bubbles are harder to bleed out than larger bubbles.
You cannot "pump up" a clutch. If you have to "pump up" the clutch to make a shift then you have a leak and you can bleed the system a dozen times to no avail.
On the clutch, think about it now, if you could "pump-up" the clutch wouldn't the T.O. Bearing tend to invert the clutch diaphragm and travel toward the engine until it met up with something solid like the flywheel. On a braking system, when you "pump-up" the brakes you force the brake pads into the rotor until the line pressure builds up enough that the resistance you feel when pumping the pedal increases. Further, as you press harder and harder on the brake pedal the pads just increase their pressure on the rotors.
GM Thought this through when they designed the system. To avoid "pumping up" the clutch hyd. system, GM put in a small bleed back hole in the master cylinder. (BTW not an original idea, all Hyd. clutches have it) This bleed back hole relieves line pressure every time the pedal is at the top of the stroke. Didn't you notice when you "pumped up" the clutch pedal that it doesn’t firm-up like the brake pedal does?
The only thing you accomplish when "pumping up" the clutch pedal is to take any air bubbles that are in the system and atomize them into smaller air bubbles, thus making the problem worse. Remember when you were at the soda shop, as a kid, and your parents kept giving you hell about playing with you soda and straw? Same theory here! The more you move that soda through the straw the smaller the air bubbles become.
BTW the "hand pumps" work ok but I’ve never needed to buy one yet. With the hand pumps you still need to ensure that the slave cylinder gets completely bled.
v8archie
PhatMax
Report this Post06-19-2023 02:11 PM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shemdog…. Worked like a charm !
shemdogg
Report this Post06-19-2023 09:41 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well done sir!
I got one! I got one woooooooo!
shem
