  Name this melted connector!
Name this melted connector! by tbone42
Started on: 06-21-2023 10:54 PM
Replies: 6 (621 views)
Last post by: PhatMax on 06-22-2023 08:51 AM
tbone42
Total ratings: 127
Report this Post06-21-2023 10:54 PM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
86 2.5 5 speed Isuzu
Had a fire. Could have been way worse. I have a few connectors and senders I need to replace, and this is basically the only unknown soldier. 2 wire comes from harness to connector, then from other side of connector goes down into the manual trans case. Soooo...i need a proper name so I can find the connector.
Thanks!
[This message has been edited by tbone42 (edited 06-21-2023).]
Tybalt
Report this Post06-21-2023 11:19 PM Click Here to See the Profile for TybaltSend a Private Message to TybaltEdit/Delete MessageReply w/QuoteDirect Link to This Post
Weatherpack
Report this Post06-21-2023 11:47 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
likely BU Light Switch in the trans.
If just have "Surface damage" then can let stay there. Wire don't carry a lot of amps the light 2 bulbs.
If wires are good, can replace weather pack shells w/o cutting but need right tool to remove the "pins."
New shell don't have the clip that holds it. Clips are separate part and many vendors don't have.
sleek fiero
Report this Post06-21-2023 11:54 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your really worried about it just get a two wire connector from the autoparts store. It could be deutz or any other brand of connector.
Report this Post06-22-2023 12:14 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Green and blue wires in that location are for the back up light switch.
tbone42
Total ratings: 127
Report this Post06-22-2023 01:21 AM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks everyone, great info. Wires seem fine, backup lights work so I'll try to either get a generic weather connection or see if I can get the pins out.
PhatMax
Report this Post06-22-2023 08:51 AM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Connector is trash…..easy way to remove pins is cut plastic a little at a time until the pins are exposed
