  High idle problem, unable to solve.
High idle problem, unable to solve. by ketstang
Started on: 07-07-2023 08:27 PM
Replies: 34 (805 views)
Last post by: ketstang on 10-18-2023 05:00 PM
ketstang
Report this Post07-07-2023 08:27 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have read all the threads on high idle here and tried all the fixes and still can't get the car to idle below 1500 rpm. I mean I must have printed out a dozen threads and tried all their tests and possible fixes.
History: Car sat for 12+ years with old gas, gas tank was rusted out. That is when I got possession of it.
Work done - I put in a brand-new gas tank, sending unit, fuel pump and filter, all new rubber and metal lines from fuel tank to fuel rail. Fuel rail was taken off and cleaned, new injectors and fuel pressure regulator. All O-rings and gaskets on upper plenum were replaced with new. New TPS and IAC installed. New air filter.
I can cover the IAC port inside the intake area of the throttle body and the car idle will drop down to 800 and sometimes it will die, sometimes not.
I removed the IAC valve, and I can get the idle to drop down.
We have tried the propane hose test, carb cleaner test and Monday we did the cigar smoke test. Can't find any leaks.
Today I did the Pepsi can between the EGR tube and bottom of the upper intake thing and it is still is idling high.
It starts fine and idles rough around 1000 rpm for a few minutes. Then the idle starts fluctuating between 1000 and 1500 rpm, eventually the idle rises above 2000rpm.
I am at a loss on what to try next. I'm hesitant to dump any more money into the repair because it's not my car and the owner has spent a ton of money on all these new parts already.
Could the problem be the ECM and is there a way to test the ECM?
I have a new IAC valve installed. Is there a way to make sure it is getting power? I read in one of the posts that a guy wasn't getting power to his IAC (problem at connector), but he didn't post details about what the fix was.
[This message has been edited by ketstang (edited 07-07-2023).]
Report this Post07-07-2023 08:36 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Idle Will Stay High if can't drive above 35mph after battery is discon or dead.
See vac leak page in cave.... https://web.archive.org/web...cast.net/~fierocave/
ketstang
Report this Post07-07-2023 08:42 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have disconnected the battery for a couple minutes and then drove the car about ten miles with speeds up to 50 mph. When I get back home and put it in neutral the idle speed is 2000-2500rpm.
I will look at the link you posted for more ideas.
Thanks for replying.
Kevin
A_Lonely_Potato
Report this Post07-07-2023 10:49 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
you can check that the IAC is functioning by setting key to ON with diagnostic mode pins jumpered. the IAC will audibly be etiher extending or retracting(i cant remember which.) shut off, pull out the IAC after ~30 seconds of this. then if the IAC pintle is extended, push it back in. repeat, and if it is extended the second time, you'll know its moving.
Total ratings: 465
Report this Post07-07-2023 11:08 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Covering the IAC port takes the IAC valve out of the equation... but to rule out if too much air might be getting past the TB butterfly valve (due to a messed-with idle stop screw), simply cover the entire TB opening while the engine is idling. If the engine still runs with all air being blocked from entering the TB, then there's definitely a vacuum leak somewhere. In this situation, there's no real point messing about with the IAC valve until you find where the air's getting in.
[This message has been edited by Patrick (edited 07-07-2023).]
buddycraigg
Total ratings: 478
Report this Post07-07-2023 11:51 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you remove the IAC and cover the hole, it should stall.
If you remove and cover the IAC hole, and the top of the TB it should definitely stall.
I bet Patrick is on the right path, and you have a vacuum leak.
Spoon
Total ratings: 61
Report this Post07-13-2023 08:13 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The most often placed missed for solving high idle on 2.8 is the cold air tube hidden behind and below the throttle body. It's a hard plastic elbow with o-ring seal that connects TB to the intake via a short section of rubber hose. My hose was mushy almost to a goooo feeling and the O-ring on the TB end was not a tight fit. At this stage it will always suck air and keep the idle high.
Another cause would be poor grounds between engine to body, engine to chassis, a weak or corroded negative battery cable, IAC connector dirty, etc.
see pic below,, Borrowed pic, Disregard the arrow. See item 5.
Spoon
[This message has been edited by Spoon (edited 07-13-2023).]
Jeffdylanproctor
Report this Post07-13-2023 10:19 PM Click Here to See the Profile for JeffdylanproctorSend a Private Message to JeffdylanproctorEdit/Delete MessageReply w/QuoteDirect Link to This Post
My car was having a very similar issue and it turned out to be the Coolant Temperature Sensor that was causing the high idle, as evidently the ECM wants the idle high till it reads a certain temp. These cars have two temp sensors, one that goes to the gauge, and one that goes to the ECM.
The one that goes to the ECM and causes the Idle issue is up right under the Thermostat housing. it is a little tricky to find and see, but it is very easy to remove. The factory plugs tend to have issues as well, and you can easily buy a plug with the sensor.
The high idle was driving me up a wall and this fixed it. Sounds crazy, but this sensor can cause a high idle.
[This message has been edited by Jeffdylanproctor (edited 07-13-2023).]
Total ratings: 465
Report this Post07-13-2023 10:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd say it's number two after a cracked EGR tube, but yeah, it's hidden away and easy to miss.
Originally posted by Jeffdylanproctor:
My car was having a very similar issue and it turned out to be the Coolant Temperature Sensor that was causing the high idle...
You bring up a very good point, although a scanner or WinALDL would point out that issue pretty quick.
However, also keep in mind that a bad CTS would not enable an engine to idle at a high RPM with all air blocked from entering the TB (unless there was also a vacuum leak).
[This message has been edited by Patrick (edited 07-14-2023).]
ketstang
Report this Post07-26-2023 12:31 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
I followed your instructions and the pintle did move. So my IAC is good and working then?
ketstang
Report this Post07-26-2023 12:34 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
ketstang
Member since Feb 2023
I completely covered the TB intake and the engine died immediately.
ketstang
Report this Post07-26-2023 12:37 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
ketstang
I removed the IAC and covered the hole and it didn't stall.
I then covered the TB intake and it did stall.
ketstang
Report this Post07-26-2023 12:45 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
ketstang
Spoon
I'm still messing with this issue. I decided to remove the upper intake again and I'm going to check all the vacuum hoses on the vacuum schematic on the decklid.
While I'm in there I'll check the cold air tube you mentioned and its hose/seal. I'll check your other suggestions as well.
I thank all of you in this forum for your patience with me and for your help!
ketstang
Report this Post07-26-2023 12:49 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
ketstang
Thanks for the tip! I will definitely be checking this next.
ketstang
Report this Post07-26-2023 01:00 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
ketstang
I did check the EGR flex tube yesterday when I took off the upper intake and it looked good.
Wish I had a scanner or WinALDL to use.
I'm going to try all the suggestions I replied to today. If it were my car I would go ahead and spring for the stainless-steel vacuum line kit, just to remove one more possibility, but it's my brothers and I'm sure he is tired of me asking for more money, LOL. He says I am "obsessed with fixing this high idle problem". I just want to get it below 2000 rpm before I return the car to him.
I'll post my finding once I FIND the problem. TY
Total ratings: 465
Report this Post07-26-2023 03:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Were you able to check the entire length of the tube? Seems to me the insulating jacket does a good job of hiding most of it.
I don't quite understand the point of removing the IAC valve.
With the IAC valve installed, and the IAC port in the TB covered, the engine should stall.
It's possible that the idle stop screw has been messed with and the butterfly valve is open slightly too far. Has the plug that normally covers the head of the screw been removed?
[This message has been edited by Patrick (edited 07-26-2023).]
PhatMax
Report this Post07-26-2023 04:01 PM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just throwing this out there but are you sure the tach is correct ? I have an issue that the tach says it idling at 2-3k when it’s not. I did install Rodney’s tach filter but still have the same prob…..I’ll have to dive into the tach itself.
shemdogg
Report this Post07-26-2023 08:25 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance the throttle cables stuck? One time messing w my intake, I had a high idle I couldnt figure out till I looked at the fuel rail. One injector didnt seat 100% and there was my yuge vac leak.
shem
A_Lonely_Potato
Report this Post07-28-2023 08:21 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
mine is horribly erratic. at idle it shows about 1400, but idling in 1st itll show almost 3k. 6k is more like 4.5k, and redline is kinda where the "X1000" is
i checked mine's accuracy by driving in 5th at 55MPH, and doing the math for what engine RPM i should be, given the tire diameter, gear ratio, and speed. i used this calculator
the IAC itself is working then. covering the port in the TB intake will eliminate the IAC from the equation if it doesn't stall like patrick and others have said.
Report this Post07-28-2023 09:54 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes Tach goes wrong, speedo too. Short reason...
The Tach and Speedo have a "chip" to run the display.
Is "programed" by resistors and capacitors for numbers printed on the back to match 0-max of numbers and ark they are on.
Example: 85 miles covering nearly 300° arc on a speedo
Caps &/or resistors can "die" for several reasons and screw up the display... "chip" is still working "right" but has wrong programing now.
Many "fix" the Resistor(s) but often bad cap and gets worse because fixing/adjusting wrong part.
So don't trust either when have problems.
Use a "Shop Tach" of many types
Anything w/ GPS can check Speedo but GPS "chips" calc Speed locally and most chips lag actual speed. So only works well on roads that allow you to drive @ X speed for many minutes.
or use ECM scanner to check Tach and Speedo accuracy.
ketstang
Report this Post08-03-2023 01:32 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could this Holley be the OEM throttle body? Still trying to track down my high RPM. The cap is still over the throttle adjustment screw, so it looks like it hasn't been tampered with.
ketstang
Report this Post08-03-2023 01:34 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone see anything that would be of concern in these pictures?
ketstang
Report this Post08-03-2023 01:42 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
ketstang
Last questions of the day, I promise.
Is there anything special about this vacuum connection block? It's pretty dried up. Can I remove it and just put hoses between to connect the two lines?
While I am this far into the hoses and have the upper intake removed, is there a problem with removing the two hard lines going from the radiator filler neck to the throttle body? The car is in the midwest and not driven in the winter.
Total ratings: 465
Report this Post08-03-2023 03:38 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think it's "anything special", but it performs double duty by connecting hoses and keeping the two lines tethered together.
It's a common mod. I've done it to a couple of my Fieros with no issues.
Total ratings: 328
Report this Post08-07-2023 12:28 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would invest in buying a low cost smoke machine that runs on compressed air and baby oil. If you already have a small air compressor you can buy the economy model for about $30.
fierogt28
Report this Post08-09-2023 03:05 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
I found out and had the same experience as Jeff. I had a bad CTS. Remember, these cars are getting old, and we’re old heck, 15 years ago. This happened to me in 2009, so yes, GM at the time had quality components or sensors on GM products, but will not last forever. Plus, it’s common an engine is rebuilt , and the owner just swaps the sensors to the rebuilt engine. I would recommend replacing all sensors for peace of mind. The only sensor is Fiero owners really can’t get anymore is the cold start sensor that is originally made by Bosch. Another tuffy is the EGR vacuum solenoid.
All other sensors are AC Delco parts available today.
So, that’s my experience I have to share if that helps anyone.
fierogt28
88 GT, Loaded, 5-speed.
ketstang
Report this Post08-17-2023 09:43 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am going to replace the coolant temp switch since it is inexpensive, and I am running out of options. Knowing there are two coolant temp sensors, when searching how do I tell which part number is the one that interacts with the ECM. Any help would be appreciated.
ketstang
Report this Post08-17-2023 09:46 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
ketstang
I'm going to see if I can find a smoke tester cheaply. I tried the cigar smoke into a vacuum trick but couldn't see a leak.
Total ratings: 465
Report this Post08-17-2023 09:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am going to replace the coolant temp switch since it is inexpensive...
It's not a "switch".
The coolant temperature sender is for the temperature gauge.
The coolant temperature sensor is for the ECU.
The manifold air temperature sensor is also for the ECU.
The ECU needs correct data from both temperature sensors to help set the correct idle speed.
A scanner or a laptop with WinALDL (and a cable) will show you what information is being fed to the ECU by all sensors... or you can blindly throw components at the problem!
[This message has been edited by Patrick (edited 08-17-2023).]
sbauco
Report this Post08-18-2023 07:17 PM Click Here to See the Profile for sbaucoSend a Private Message to sbaucoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure if this would apply to the 2.8, but my '88 2.5 had this exact same problem when I first bought it; it would just randomly idle super high and stay there. In my case I had also already replaced the TPS, but with the lowest quality bargain basement option. After a ton of investigation, I discovered that the sensor would act erratically and sometimes read high, making the ECM think the throttle was open when it actually wasn't. Then, the ECM would command the IAC overly open and cause a high idle. Once I bought a higher quality TPS, my high idle completely went away.
Vintage-Nut
Report this Post08-18-2023 08:44 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not a "switch". The coolant temperature sender is for the temperature gauge.
Both of you are 'right'.....
Sensor/Sender, Coolant Temperature (GM 25036809)
Two Circuits in One:
Variable Resistor for the gauge
Switch for the coolant temperature warning light (bulb)
Edit: This unit is for the temperature gauge and warning light ONLY
IF you're SURE that you don't have any vacuum leaks, and still have 'High Idle Problems'
Replace the engine coolant temperature sensor for the ECM (GM 25036979 for V6)
[This message has been edited by Vintage-Nut (edited 08-19-2023).]
Total ratings: 465
Report this Post08-18-2023 08:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not really. The OP expressed an interest in replacing the coolant temperature sensor for the ECU, not the sender for the temperature gauge. There is no "switch" whatsoever in the coolant temperature sensor for the ECU.
I still strongly suggest that the OP find out what's going on with his engine by getting a reading of all the sensors first before randomly replacing them.
[This message has been edited by Patrick (edited 08-18-2023).]
cyrus88
Report this Post08-19-2023 12:51 AM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
. . . before randomly replacing them.
Where's the fun in that? Shotgun approach is the best way to keep one busy.😁
Vintage-Nut
Report this Post08-19-2023 10:03 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
As Fierogt28 said "I would recommend replacing all sensors for peace of mind"
I did too!
ketstang
Report this Post10-18-2023 05:00 PM Click Here to See the Profile for ketstangSend a Private Message to ketstangEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, wanted to get back to everyone on my high idle problem. After several suggestions to replace the coolant temperature sensor for the ECU, I did and stated that it didn't seem to work. I have now driven it 100 miles and it is now idling at about 1500rpm at startup but slowly idles down to 800rpm. I am very satisfied with this and want to thank all of the people who have helped me along the way!
I have a newly found problem, but that's for a new thread. It's unbelievable (to me anyway).
