  Rearview mirror button and mirror opening measurement question/issue
Rearview mirror button and mirror opening measurement question/issue by Trinten
Started on: 07-09-2023 08:25 PM
Replies: 12 (239 views)
Last post by: Vintage-Nut on 08-22-2023 11:06 AM
Trinten
Report this Post07-09-2023 08:25 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
What do you guys measure the width of the rearview mirror button at the widest point in your cars?
And if you use the 'blade' side (opposite side from the 'pinchers') what is the opening at the base of the your rearview mirror, inside the channel where the button would go?
When I had my new windshield put in a few years back, they said they put in a Fiero 'button'.
I couldn't find my rearview mirror, so I ordered a used one from the Fiero store. It arrives. It won't slide on. It barely starts (there's no screw in it). I tried using a little force, but I don't want to crack my windshield.
Perplexed, I use calipers to measure the width of the button at it's widest point: 0.975.
I use the 'blade' side of the calipers to measure the opening of the rearview mirror I got from TFS at the opening: 0.902. Well, that certainly is an issue.
Fast forward a bit, I'm in the junkyard getting parts off an '88 Fiero. It has the mirror in there, though it's in BAD shape. However, still good for measurements!
Junkyard button: 0.98
Junkyard mirror opening at it's widest point: 0.966
This is closer and makes sense, the mirror has to be a tiny bit smaller to help seat securely on the button.
So now I'm trying to figure out - is the parts I found/measured in the junkyard aftermarket, or did I get some oddball mirror from TFS?
I couldn't find any info on this in my searches. So thought it might be useful for others as well as myself. I did find a Dorman replacement rearview mirror (part 76502) that says it uses a 0.98 wide button, so I am going to order that and see if it works.
buddycraigg
Total ratings: 478
Report this Post07-09-2023 09:11 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let us know if it works out.
Vintage-Nut
Report this Post07-10-2023 11:03 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
by Trinten:
From my '88 OEM Rearview Mirror:
Windshield 'Button' at its widest point is 0.970"
Mirror opening for the 'button' at its widest point is 1.0"
Trinten
Report this Post07-10-2023 11:19 AM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you!
Definitely seems to be some variations out there - unless someone sent a non-Fiero rear view mirror to TFS. Maybe I should have bought one of their reproductions.
I did email Dorman for some clarification, because they have another button (part 76975) that is also 0.98 wide at the base, and is listed specifically for the Fiero. So I guess there could be other unlisted differences, such as angle of the "wings" off the button, or the thickness of those.
This could be a not-so-fun game of trial and error. You'd think the automotive industry would be okay with making some parts universal. lol
[This message has been edited by Trinten (edited 07-10-2023).]
John W. Tilford
Report this Post07-10-2023 11:58 AM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a mirror from a junkyard. Took it out of a GM SUV. My original 1988 GT mirror was internally corroded. The GM mirror looked new and offered outside temperature and compass.
Back to your issue: the GM mirror slid on the Fiero mirror mount (glued to glass) with no problem. Tightened easily. GM mirror works great, looks good. $25.
Took me about a day to get the temperature sensor mounted in front of the Fiero radiator and - worse part - run the sensor wire to the mirror. Power is available inside the Fiero overhead light box. I put a miniature switch on the edge of the box.
Hazard: the power inside the overhead light box is "on" all the time. I forgot to turn the mirror power off before a two week vacation once = dead battery.
John W. Tilford
Trinten
Report this Post07-10-2023 12:07 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks John!
That's a great tip. Right now the biggest thing is to find out if it's a normal GM button (that second button part number I listed, does show a wide variety of compatible GM cars and SUVs on the Dorman site), or if it's a Chrysler/VW button (the first part number I listed from Dorman). The next time I'm at my buddy's house I might kidnap his Fiero mirror and see if it slides onto my button or not. That will help eliminate the question about what base is in my car.
I don't know why I didn't think of that sooner... it's been a long month.
css9450
Total ratings: 87
Report this Post07-10-2023 12:08 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
LOL I did that too! I had to charge the battery after a few days of it showing "N" on the compass.
I'm using a Cadillac compass mirror in my car. It's from the junkyard...... No temp though.
Report this Post07-10-2023 04:56 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Size/Shape of "Button" on glass depends on Year.
Think is 86⬇️ vs 87⬆️
The ⬆️ Mirrors won't fit ⬇️ Button and other way around.
Believe Is also why when order new windshield what to know what year car because Button are attach at glass maker.
They use way stronger "glue" that you or most glass dealers can get and prepare the both better too so won't fall off often in months.
If have right mirror for the car... Likely have replace the glass for "wrong" year.
If because TFS likely send wrong mirror.
Trinten
Report this Post07-10-2023 05:07 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Ogre!
That's crazy that Pontiac/GM even changed the freaking rearview mirror / base over the years.
I'm going to keep my fingers crossed that the Dorman mirror works. Mike's Fiero is also an 87, so that'll be a good test as well. If neither work on the exiting button, it looks like the Dorman mirror comes with the button for that mirror - I guess I'll need to use the epoxy/glue to marry the buttons together and put the mirror on that way.
Trinten
Report this Post08-21-2023 08:20 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a quick follow up on this -
I took the used mirror I bought from TFS and it would not fit on Mike's 87 windshield mounting button either. Unsurprisingly, his mirror did not fit on mine.
So this goes back to what Ogre said, if PGW was putting buttons on the glass at the factory, then this is a windshield for another year Fiero, likely an earlier year.
So I still am going to try to hunt down an aftermarket or NOS 86 Fiero rear view mirror and see if that works, if not, I'll take John's path and get a few different GM ones from a junkyard to see if any of them fit.
Last option... do the "double button" solution, and glue the 'right' button on top of this one. *sigh*.
Vintage-Nut
Report this Post08-21-2023 11:28 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
My OEM glue failed years ago and to me, I enjoy not having the rearview mirror on my Fiero windshield!
I 'hated' the inner rearview mirror in the night as the Fiero sits lower than normal cars or worse; 4X4 trucks or 18-wheelers.
Report this Post08-22-2023 12:50 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many to Most should have the "dimmer button" on the mirrors for that reason. Because way bigger vehicles have same problem @ night.
How an anti glare rear view mirror works https://www.youtube.com/watch?v=XZPuYaxQbJw
(Some vehicle have Electric mirror dimming and may not have the button on them.)
[This message has been edited by theogre (edited 08-22-2023).]
Vintage-Nut
Report this Post08-22-2023 11:06 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes Ogre, the factory Fiero mirror has a "dimmer button" however, I don't miss the mirror.
Personally, I enjoy BETTER without hanging it on windshield and I'm used to driving dual exterior rearview mirrors with blind spot mirrors.
