  Needing Assistance Identifing Unconnected Plugs
Needing Assistance Identifing Unconnected Plugs by Fieros4evr
Started on: 07-21-2023 10:24 AM
Replies: 9 (187 views)
Last post by: theogre on 07-22-2023 07:38 PM
Fieros4evr
Report this Post07-21-2023 10:24 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello All,
I bought a 1987 Fiero, 4 Cyl Iron Duke 5 Spd. I found these unconnected plugs/wires in the hood compartment and I have no idea where they connect or their specific purpose. The previous Fiero owner didn’t know either. The first photo is a connector located near the clutch slave cylinder area and the other wires/plugs in the other photos were from a wire cluster near the right side of the TBI facing the engine bay. Any help identifying these would be appreciated.Thanks!
[This message has been edited by Fieros4evr (edited 07-21-2023).]
Report this Post07-21-2023 10:43 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
1 & 3 look like AC Compressor plugs. 1 for the clutch 3 for limit switches.
2 O2 sensor.
4 link is "dead" because posted wrong somehow and I'm not trying to guess.
you change order... Now...
1 purple O2 sensor
all others for AC compressor. Flat one Clutch, Others Limit Switches.
[This message has been edited by theogre (edited 07-21-2023).]
Report this Post07-21-2023 10:49 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Number 4 is for the A/C compressor clutch.
Fieros4evr
Report this Post07-21-2023 10:52 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for responding theogre.I noticed too errors with my ad.Since that happened, I will explain separately. This image is a plug near the clutch slave cylinder
Fieros4evr
Report this Post07-21-2023 10:55 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieros4evr
Member since Jul 2023
These images tie to the wire cluster and each image are all on a small wire cluster near the TBI:
Fieros4evr
Report this Post07-21-2023 10:58 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieros4evr
Thanks again theogre. Your information really helped me.
Fieros4evr
Report this Post07-21-2023 11:11 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieros4evr
Thank you olejoedad.
Report this Post07-21-2023 01:11 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Flat connector to clutch... The small "barrel" on wire side is a Diode.
This Diode Must Work when connected and clutch is On or when Clutch turns Off the Power Surge from the Clutch Coil can Kill other electric parts.
The Surge is Negative 700 volts or more and can "blow thru" the Relay and kill other things.
Because plug wires go to ground and AC relay. Standard Diode Test on any Ω meter will show working or not.
You can replace the Diode by getting a "kit" that plugin between coil and OE plug.
Diode is maybe 1N4007 1000v or even higher volt breakdown.
Fieros4evr
Report this Post07-21-2023 07:36 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the info regarding the diode. I have an update to this ad: So I found the O2 sensor and I had to laugh when I saw it. The connector melted on the top edge of the motor. I will have an update with the compressor soon.
Report this Post07-22-2023 07:38 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
O2 plug is standard 1 pin Weather Pack shell.
If other half is good, a new O2 sensor have the other half.
God knows how old the Sensor is. New one can help many problems even have no "code" set by ECM.
