  Where is my tensioner? 3800sc
Where is my tensioner? 3800sc by sdgdf
Started on: 07-24-2023 12:21 AM
Replies: 5 (240 views)
Last post by: olejoedad on 07-27-2023 11:19 PM
sdgdf
Report this Post07-24-2023 12:21 AM Click Here to See the Profile for sdgdfSend a Private Message to sdgdfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tensioner? For my alt/waterpump/ac not my supercharger. I thought it’s the one between the alt and waterpump, but I can’t move it. How does the belt go on and stay tight? All I can see is removing the alt gets the belt on/off?
Total ratings: 206
Report this Post07-24-2023 07:55 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is the one between that alternator and the water pump, and you rotate it counter clockwise to loosen the belt.
sdgdf
Report this Post07-24-2023 09:57 PM Click Here to See the Profile for sdgdfSend a Private Message to sdgdfEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suspected that but I can’t get it to budge. If I google there’s old threads where people say they can’t fit the normal tensioner so they build the alternator bracket so it holds the belt tight, I’m hoping that’s the case here.
Total ratings: 206
Report this Post07-25-2023 11:30 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use a longer lever?
I see you here is no power steering pump on the engine, perhaps the belt on your engine is so short that the tensioner is already at full rotation?
sdgdf
Report this Post07-27-2023 08:21 PM Click Here to See the Profile for sdgdfSend a Private Message to sdgdfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use a longer lever?
Ok sure enough, I went to the jy today and worked it on a Grand Prix there, mine turns but with a lot more effort, ty.
Total ratings: 206
Report this Post07-27-2023 11:19 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Happy to help!
