  Crank no start
Crank no start by Papastone
Started on: 07-26-2023 05:38 PM
Replies: 5 (502 views)
Last post by: IMSA GT on 08-25-2023 06:48 PM
Papastone
Report this Post07-26-2023 05:38 PM Click Here to See the Profile for PapastoneSend a Private Message to PapastoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 2.5 there's juice going into the coil, no spark or spray out of the throttle. Any idea what I need to replace
shemdogg
Report this Post07-26-2023 08:07 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year? Early 4 banger had a distributor, later had dis. Any codes? Check fuses? Check fuel pressure? Check engine light working? Tried starting fluid? Good battery?
shem
Spoon
Total ratings: 61
Report this Post08-02-2023 04:58 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
"no spark" possible bad coil, "no spray" possible bad fuel pump.
"No" to both at the same time would be rare. Check fusible links and fuses.
Spoon
buddycraigg
Total ratings: 478
Report this Post08-24-2023 11:59 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the engine crank?
What year is it?
Total ratings: 200
Report this Post08-25-2023 12:32 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, couple of additional questions:
- What year is it? 84, 85-86, 87-88?
- When was the last time it was running?
- What happened when it stopped running?
Thanks!
IMSA GT
Total ratings: 253
Report this Post08-25-2023 06:48 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by IMSA GT (edited 08-25-2023).]
