  Hard Manual Shifting Into Gears (Page 1)
Hard Manual Shifting Into Gears by Fieros4evr
Started on: 08-03-2023 03:01 PM
Replies: 46 (697 views)
Last post by: jelly2m8 on 10-21-2023 11:05 PM
Fieros4evr
Report this Post08-03-2023 03:01 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can imagine there have been numerous postings about this problem and was able to find a couple of topics, but I decided to discuss my situation in detail. I have a 1987 Base / Iron Duke / 5 Speed. Master & Slave replaced yesterday, bled 3+ times and nothing has improved shift wise. When the engine is off, I can shift in all gears with the clutch pushed and not pushed. But when the engine is running, no shifting allowance in any gears. My do-it-yourself fiero repair level is low experience and I am reaching out to see if anybody could provide their thoughts towards this problem. Thanks in advance.
[This message has been edited by Fieros4evr (edited 08-03-2023).]
Total ratings: 465
Report this Post08-03-2023 03:24 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
This has been discussed about a million times at this forum. Here are almost 70 threads to start with. There are only so many ways we can ask... how far above your brake pedal does the clutch pedal sit at rest... how far does your slave move when the clutch is pushed to the floor... etc.
Did you buy a double seal slave from Rodney? If not, you've made things much tougher on yourself.
[This message has been edited by Patrick (edited 08-03-2023).]
Fieros4evr
Report this Post08-03-2023 06:21 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Patrick,
Thank you for responding. Here is the current positioning of the clutch pedal
Fieros4evr
Report this Post08-03-2023 06:32 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieros4evr
Member since Jul 2023
I couldn’t download the short video of the slave cylinder in action, but the first photo shows the slave cylinder not depressed. The second photo is the slave cylinder status with the clutch pedal pressed towards the floor.
stevep914
Report this Post08-03-2023 06:55 PM Click Here to See the Profile for stevep914Send a Private Message to stevep914Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am no expert, but have been through this myself. First, your photo shows a clutch pedal LOWER than your brake pedal- should be the other way around. Second, your clutch pedal arm appears to be twisted- a common problem with many Fieros. The travel on your slave pushrod from your before and after photo would indicate not enough pushrod travel to activate the clutch. I would go first with the bent clutch pedal; replacing that would maybe solve your problem. Look at it underneath and see if the pin for the master pushrod and banjo is at right angles to the rest of the pedal arm. There are threads with pictures that show the good and the bad ( I don’t know how to download them. ) If that doesn’t fix your problem, bleeding procedure is also well covered on this forum. There is, as Patrick stated, TONS of info dealing with this issue. At some time or another, all of us will probably deal with it!
Fieros4evr
Report this Post08-03-2023 07:31 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stevep914, Thank you! The information you’ve provided is appreciated. I am new to this website and will look for more information related. Have a good day.
Total ratings: 465
Report this Post08-03-2023 07:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by stevep914:
...your clutch pedal arm appears to be twisted- a common problem with many Fieros.
Steve, we've been down this road before.
One other thing: I believe my pedal is aluminum, not steel it has an interesting twist in it. Not knowing what anything other than mine looks like, and assuming a bent pedal would provide a consistant problem, I don’t know if this is a contributing factor. Anyone able to post a picture of a normal clutch pedal I could compare mine to? I know many have converted to a steel pedal when the stock one bent.
Originally posted by Patrick Here:
Steve, they all have an "interesting twist". That's how they're made. What you're looking for is a bent bracket on the pedal. I first posted this photo of my clutch pedals ages ago.
If your clutch pedal sits 1-1/2" above your brake pedal as you reported, it's probably fine... although I still think that's higher than usual. Is your banjo adjustable?
Total ratings: 465
Report this Post08-03-2023 07:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
Fieros4evr, your clutch pedal is definitely bent. An adjustable banjo may rectify the problem.
This is one that I made using a 5/16"-18 coupling nut...
Those images of your slave movement would be great... if you had placed a tape measure or ruler in view to show the distance it's traveling. I suspect however with the amount your pedal is bent that it isn't the 1-1/8" required.
Fieros4evr
Report this Post08-03-2023 09:27 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Patrick for your recommendations. Attached are 2 images. I did the best I could placing the ruler in that limited space area. The first photo is the clutch slave measurement without the clutch pedal not pushed. The 2nd image is the clutch cylinder extended distance with the clutch pedal pressed towards the floor.
Total ratings: 465
Report this Post08-03-2023 09:40 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, unfortunately it's next to impossible to tell from those photos how far the slave is actually traveling... but you now know it needs to be at least 1-1/8".
When the clutch pedal bracket gets bent, the pedal then hits the floor before the master is able to travel its full stroke... which then limits the travel of the slave. An adjustable banjo can often help regain enough travel... as long as the pedal isn't bent excessively.
Fieros4evr
Report this Post08-04-2023 01:04 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I really appreciate all your help Patrick. I have started looking for a new clutch pedal and will order a replacement. I am also going to do what you did making an adjustable extension to the banjo. I will keep you posted with the results.
[This message has been edited by Fieros4evr (edited 08-04-2023).]
Total ratings: 465
Report this Post08-04-2023 01:34 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have started looking for anew clutch pedal and will order a replacement. I am also going to do what you did making an adjustable extension to the banjo.
You should only have to do one or the other.
Make sure the cause of your low pedal isn't simply a bent banjo. It does happen.
And yes, the loop is installed pointing up.
[This message has been edited by Patrick (edited 08-04-2023).]
Fieros4evr
Report this Post08-04-2023 02:28 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
That photo helps. Thanks. So I decided to go and take a closer look underneath the d/s dash for a closer look at the clutch setup. Here is what I am seeing:
What is this pink/yellow wire for? I noticed that added wire to the connector.
I also noticed that the white plastic piece is not functional and hanging loosely to the top clutch pedal arm, What does that do? Thanks.
Fieros4evr
Report this Post08-04-2023 02:30 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieros4evr
Total ratings: 465
Report this Post08-04-2023 03:18 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That white switch, which has been bypassed with a jumper, is a safety feature to prevent trying to start the car while in gear. With the way it was configured at the factory, the starter couldn't be energized unless the clutch pedal was depressed.
Fieros4evr
Report this Post08-04-2023 03:30 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank You. Patrick, You have taught me a lot today. I was looking at the master cylinder rod that you mentioned. (Photos below).So far not bent and it was positioned just like your photo. I ordered the clutch pedal. I will let you know when it arrives and is installed.
Total ratings: 465
Report this Post08-04-2023 04:37 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your banjo to pedal mount looks rather funky. I suspect you have a mismatch going on there. This page will explain it.
stevep914
Report this Post08-04-2023 06:13 PM Click Here to See the Profile for stevep914Send a Private Message to stevep914Edit/Delete MessageReply w/QuoteDirect Link to This Post
As usual Patrick’s info is spot on,! Your tape measure photos show only about 1/2 inch of slave travel - far from enough. Either the pedal replacement and/or adjustable banjo should give you enough. Trust me ; been there done that!
Fieros4evr
Report this Post08-05-2023 03:40 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can’t thank you both enough. This information is greatly appreciated. I will plan on switching out the pedal and banjo. I will provide an update once these parts are replaced.
Fieros4evr
Report this Post08-14-2023 10:42 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
- UPDATE -
Finally, The new clutch pedal & bushings arrived. I will have a following update once this is installed. Please feel free to share any thoughts or advice.
[This message has been edited by Fieros4evr (edited 08-14-2023).]
Total ratings: 465
Report this Post08-14-2023 10:52 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
First thing... make sure this new clutch pedal fits whichever banjo you plan to be using.
Fieros4evr
Report this Post08-14-2023 11:16 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Patrick,
I will do that and show photos of the banjo attached when applied. Thanks!
Report this Post08-15-2023 12:16 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oh man... this is like the "classic" example of a bent pedal.
Fieros4evr
Report this Post08-20-2023 01:59 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are right 82-T/A .
UPDATE - I spent the evening taking out the old clutch pedal (Took me 2 hours) haha. I just finally got this pedal out. Below are photos of the old (left) & new (right) pedal side by side. I will resume installing the new clutch pedal in about 1 hour just in case I see some messages here that might be important before I proceed. You guys have been very helpful and I appreciate all your assistance as I take on this repair for the first time.
[This message has been edited by Fieros4evr (edited 08-20-2023).]
Total ratings: 465
Report this Post08-20-2023 02:24 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a reason you got the older style clutch pedal to replace the original newer style pedal?
Which style banjo do you have? As pointed out earlier, you want to make sure it matches the clutch pedal you'll be using.
Fieros4evr
Report this Post08-20-2023 02:26 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick, I checked as you told me, the banjo fitting to the new clutch pedal. The old clutch pedal had a plastic bushing mounted in between the inner loop (Photo 1). I removed the plastic bushing and the banjo fits perfectly with the new clutch pedal.
Total ratings: 465
Report this Post08-20-2023 02:32 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I removed the plastic fitting and the banjo fits perfectly with the new clutch pedal.
So now you have metal on metal, right? That's not the way it's supposed to be!
Fieros4evr
Report this Post08-20-2023 02:33 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Patrick, To answer your question about this new pedal. I ordered it on the Fiero Store website and specifically provided information that my Fiero was a 1987 Base/ 2.5L. That pedal you see was what they sent to me. I too noticed the difference of that part of the pedal. Will this work for a 1987 Iron Duke manual? Thanks!
Total ratings: 465
Report this Post08-20-2023 02:39 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you not read the info at the link I posted for you 15 days ago?
The FS has sent you the wrong pedal.
You either need to get the correct pedal... or change your banjo.
Total ratings: 465
Report this Post08-20-2023 02:45 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
I looked up the replacement clutch pedal at FS Here. They only supply the older style pedal. They try to get around this by saying... "This pedal does not require the master cylinder rod bushing (64900)." IMO, that's a BS way of supplying the wrong pedal for anyone with the newer style pedal/banjo.
Fieros4evr
Report this Post08-20-2023 02:49 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I now see your point. I will contact TFS and have it shipped on Monday to exchange. Once I receive the correct pedal, I will give a future update. I appreciate the information.
Total ratings: 465
Report this Post08-20-2023 02:50 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will contact TFS and havi it shipped on Monday. Once I receive the correct pedal, I will give al future update.
That just it... TFS does not have the correct pedal for anyone with the newer style.
Do that, send the wrong pedal back to FS, use your original pedal... and you'll be good to go.
[This message has been edited by Patrick (edited 08-20-2023).]
Fieros4evr
Report this Post08-20-2023 04:31 AM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been online pressing my luck to see if I could find my exact clutch pedal is available new…NONE!
It’s interesting to see many used clutch pedals for sale that are like mine. Needless to say “I won’t even think about it!”
I will re-install my old clutch pedal as soon as the adjustable banjo arrives from RD.
Thanks you all for your time & patience.
“And may the Pontiac Fiero Live On & Beyond!”
longjonsilver
Report this Post08-20-2023 07:48 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also get the double seal slave piston from RD. With the adjustable banjo i made and the RD (Toyota) double seal slave piston i have not had another problem.
MANY of us have been down this road. You can do it too!
sleek fiero
Report this Post08-20-2023 12:02 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
To me it looks like your old pedal is twisted. If so I would get it straightened and reinforced so when you put it back together you can use the correct original parts so the clutch will work correctly. with the pedal straightened you will get full stroke on the master cylinder and therefore full stroke on the slave. sleek
Total ratings: 465
Report this Post08-20-2023 04:25 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sleek fiero:
...looks like your old pedal is twisted.
I see that the bracket on the pedal is bent, but it doesn't appear to be too bad. I suspect an adjustable banjo will make up the difference just fine.
Fieros4evr
Report this Post08-20-2023 06:45 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will go that route getting my original pedal worked on. I tried to make adjustments myself today, but I do not have any proper setups or restraints here for me to do that. I will find a way and repair the pedal. I’m also looking forward to the adjustable banjo.
Total ratings: 465
Report this Post08-20-2023 07:36 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not unheard of to bend the pedal bracket back into shape... but the problem with doing so is that the pedal will have then been bent twice, and will now suffer from additional metal fatigue. It will therefore have a tendency to bend again more easily. Sure, you can add support by welding on some extra metal... but IMO this is all unnecessary.
As stated in my previous post, your pedal isn't bent that badly. If it was my pedal, I'd just leave it the way it is. I'm pretty confident the adjustable banjo alone will be enough to give you back full stoke of the master cylinder.
Anyway, I won't harp on this any further unless asked to do so.
Fieros4evr
Report this Post08-20-2023 09:02 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are correct that adjusting will have the tendency to bend again. But seeing that nobody sells the latest clutch pedal, that made me think to have mine fixed and add the extra reinforcement piece that other Fiero owners are doing. But anyway, Hearing from you Patrick my current clutch pedal condition, I will only get the adjustable banjo & disregard any clutch pedal work. I look forward to driving this Fiero, having easier shifting back again.
PhatMax
Report this Post08-20-2023 09:04 PM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it was mine…I’d straighten it. Bench vise and a big crescent wrench will work. It looks twisted by the pedal and the pivot point. I don’t think cold bending it will affect the strength much plus the geometry will be correct. That pedal was prob pressed thousands of times in its life.
I put in Rodney’s master and it has a bronze bushing and didn’t need the plastic one.
[This message has been edited by PhatMax (edited 08-20-2023).]
