  Hard Manual Shifting Into Gears (Page 2)
Hard Manual Shifting Into Gears by Fieros4evr
Started on: 08-03-2023 03:01 PM
Replies: 46 (697 views)
Last post by: jelly2m8 on 10-21-2023 11:05 PM
Total ratings: 465
Report this Post08-20-2023 09:27 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by PhatMax:
It looks twisted by the pedal and the pivot point.
IMO, there's no twist of the pedal that isn't supposed to be there. The pedal foot-pad and the pivot point appear to be perfectly lined up. It's the bracket that's bent (in the direction of the arrow) away from the master cylinder. The adjustable banjo should have no problem making up for that bend.
sleek fiero
Report this Post08-21-2023 03:10 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick. Mine was twisted just like that and pedal had dropped down beside the brake pedal. Yes you can mickey mouse the push rod but why not fix it properly. You think that by lengthening the pushrod that it isn't go[ng to continue bending ? Just straighten it and do a little fabrication and welding and reinforce the pedal in its proper geometry so you never have this problem again. Oh and Patrick I will be coming to Vancouver soon . I will let you know so maybe we can meet up for a beer. sleek
Total ratings: 465
Report this Post08-21-2023 06:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sleek fiero:
...why not fix it properly. Just straighten it and do a little fabrication and welding and reinforce the pedal in its proper geometry
Bill, not everyone has a shop and/or welding facilities available. I wish I did!
Correct. In my experience, the pedal doesn't get bent bit by bit slowly over the years from normal use. It gets bent from excessive force, usually applied when the clutch hydraulics are malfunctioning, and the driver tries to put the clutch pedal through the floor.
With the hydraulics fixed (thank gawd for double seal slaves), an adjustable banjo will compensate just fine for a minimally or moderately bent pedal.
That would be great. Just give me more than a few hours notice this time.
sleek fiero
Report this Post08-21-2023 06:59 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will give you more notice .If you can remove the pedal you probably have enough talent to straighten the pedal. if so take it to a local shop and probably the would reinforce it for less than 50.00 Canadian. sleek
Total ratings: 465
Report this Post08-21-2023 07:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No pedal removal necessary... and the cost was less than $2 (CDN).
Originally posted by Patrick:
Fieros4evr, your clutch pedal is definitely bent. An adjustable banjo may rectify the problem.
This is one that I made using a 5/16"-18 coupling nut...
CLICK FOR FULL SIZE
Fieros4evr
Report this Post08-21-2023 07:49 PM Click Here to See the Profile for Fieros4evrSend a Private Message to Fieros4evrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now come to think of it, I have seen that coupling nut in hardware stores.
The adjustable banjo will be arriving this week. If that were’t the case, I would’ve tried and cut my existing master/banjo and adding a coupling nut.
Thanks again you all !
[This message has been edited by Fieros4evr (edited 08-21-2023).]
jelly2m8
Total ratings: 243
Report this Post10-21-2023 11:05 PM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
If it was mine…I’d straighten it. Bench vise and a big crescent wrench will work. It looks twisted by the pedal and the pivot point. I don’t think cold bending it will affect the strength much plus the geometry will be correct. That pedal was prob pressed thousands of times in its life.
I put in Rodney’s master and it has a bronze bushing and didn’t need the plastic one.
Yep I'd just straighten / square it up, I have a 10 inch crescent wrench that just fits in up under the dash and I straighten them without even pulling the pedal from the car.
