  Rear end links for an 88 GT
Rear end links for an 88 GT by jc8367
Started on: 08-13-2023 09:35 AM
Replies: 9 (412 views)
Last post by: 82-T/A [At Work] on 08-23-2023 08:19 AM
jc8367
Report this Post08-13-2023 09:35 AM Click Here to See the Profile for jc8367Send a Private Message to jc8367Edit/Delete MessageReply w/QuoteDirect Link to This Post
What have people been using? I hear the Fiero Stores version needs cutting. Rodney's Zero Lash has many sizes, which is appropriate for my car http://rodneydickman.com/pr...29c2440aee57469e398.
What about local shops like Napa, Pep boys, Autozone or Advanced?
Thanks in advance
Report this Post08-13-2023 10:33 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Prothane and Energy Suspension both offer good quality parts.
Vintage-Nut
Report this Post08-13-2023 11:18 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put in Rodney's Zero Lash End Links which are 'plug n' play'
Edit: I installed then both on the Front and the Rear
Stock '88 Suspension
http://rodneydickman.com/pr....php?products_id=187
[This message has been edited by Vintage-Nut (edited 08-13-2023).]
Total ratings: 463
Report this Post08-14-2023 10:09 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I installed on mine. (The application says "front", but I think the front ones are longer than these.)
https://www.amazon.com/gp/product/B000CNB5GI/
sledcaddie
Report this Post08-20-2023 08:23 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
According to earlier posts, the fronts are 136mm long. The rears are 81mm.
Total ratings: 463
Report this Post08-20-2023 09:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jc8367:
What have people been using? I hear the Fiero Stores version needs cutting. Rodney's Zero Lash has many sizes, which is appropriate for my car?
IMO, it's best to measure what your particular car requires, as many cars will be a bit different than each other, especially if any suspension mods have been done. I believe it's optimum to have the end of the "arms" of the sway bar parallel to the ground while the car is sitting normally. I've borrowed this image to show what I mean.
[This message has been edited by Patrick (edited 08-21-2023).]
sledcaddie
Report this Post08-22-2023 01:23 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great photo, Patrick! Does anyone even make those nylon bushings anymore? Mine had just crumbled away.
Also, what is the rule of thumb on how much to tighten down the rubber washers? Some say to tighten until the rubber is the same diameter as the washers. Your thoughts?
[This message has been edited by sledcaddie (edited 08-22-2023).]
Vintage-Nut
Report this Post08-22-2023 04:35 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I removed my factory end links out to put in Rodney's Zero Lash End Links, both the front and rear were tightened 'all the way' when the plain machine nuts hit the end of threads of the bolts.
Edit: If you don't tighten the nuts to the end of the threads, then you'll need Nyloc nuts to 'hold' the nut positions you want on the bolts (like in the borrowed image above)
[This message has been edited by Vintage-Nut (edited 08-22-2023).]
Total ratings: 463
Report this Post08-22-2023 04:55 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I'll take credit for finding the photo... but seq gets credit for originally posting it in This thread.
I'm no authority on this... but I usually tighten the end link lock-nut until the rubber bushings are about half their original thickness. You definitely don't want any play in the end links, but I've always been leery that over-tightening and over-compression of the rubber may lead to it splitting/failing prematurely.
[This message has been edited by Patrick (edited 08-22-2023).]
Total ratings: 200
Report this Post08-23-2023 08:19 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sage advice... I've long since replaced these at least a dozen times on my cars and never thought to check / compare what it was originally. Is there a more accurate way of determining what kind of tension should exist? I always made the assumption to tighten them down until it eliminates any play.
